I own a maytag rsw 2700 refrig. motors run lights run but refrig and freezer are not cold. what should i do? Is it out of freon? where can I get it? and how much should I put in?
Hi jtc1280 when you say motors are running,does that mean the compressor motor or is this just the cooling fans.
I suggest you remove the cover on the rear bottom to access the compressor motor and check the compressor by putting your hand on the compressor be cautious when doing this the compressor may be hot if not working correctly un plug the compressor and plug back up with hand on compressor see if you can fill the compressor running this motor runs with very little noise. If this motor is very hot insure that the colling fans are working and also that the condensing coil is free of lint build up which can make the unit over heat if this area has a lot of lint build up unplug unit clean the bottom out with air hose and vacuum if no air is available just use a dust brush to clean good let the compressor cool for 30 or 40 minutes before plugging back in.
