Maybe your key fob needs a new battery !
NOTE:If the power liftgate system is turned OFF in the message center, the system cannot be activated with any switches or with the liftgate handle. The system will need to be turned ON for any power operation to occur.
NOTE:The power liftgate may not operate under the following conditions:
Power Liftgate Module Diagnostic Trouble Code (DTC) Index
Power Liftgate Initialization
If any of these conditions has occurred, the power liftgate must be reset.
Power open the power liftgate by using the keyfob or overhead console switch.
This system can also set DTC'S
DTC
Description
Source
Action
B1342
ECU Is Defective
INSTALL a new power liftgate module. REFER to Power Liftgate Modulein this section.
B2477
Module Configuration Failure
REFER to Section 418-01.
B2522
Vbatt1 Circuit Failure
GO to Pinpoint Test B.
B2552
Vbatt2 Circuit Open
B2698
Vbatt2 Circuit Failure
B2699
Left Pinch Strip Open Or Short To Battery
B2700
Right Pinch Strip Open Or Short To Battery
B2701
Left Pinch Strip Stuck Active
B2702
Right Pinch Strip Stuck Active
B2703
Open/Close Switch Stuck Active
B2704
Optical Sensor Power Short To Ground
B2705
Optical Sensor 1 Input Not Active During Powered Gate Movement
B2706
Optical Sensor 2 Input Not Active During Powered Gate Movement
B2709
Gate Open Output Short To Battery
B2710
Gate Close Output Short To Battery
B2711
Gate Open Output Short To Ground Or Open
B2712
Gate Close Output Short To Ground Or Open
B2713
Unlatch Output Short To Ground Or Open
B2714
Uncinch Output Short To Ground Or Open
B2715
Cinch Output Short To Ground Or Open
B2718
Gate Ajar Output Short To Battery
B2721
Gate Ajar Output Short To Ground Or Open
B2722
Open/Close Switch Active During Self-Test
B2723
Glass Position Switch Active During Self-Test
B2724
Forkbolt Switch Invalid During Self-Test
B2725
Detent Switch Invalid During Self-Test
B2726
Home Switch Invalid During Self-Test
B2819
Gate Motor Circuit Short To Battery
B2820
Gate Motor Circuit Short To Ground Or Open
B2821
Cincher Motor/Unlatch Actuator Short To Ground Or Open
B2822
Cincher Motor/Unlatch Actuator Short To Battery
B2825
Movement Ceased Due To Excess Speed Deviation
B2903
Chime Output Circuit Short To Battery
Power Liftgate Module/ Liftgate Chime Module
GO to Pinpoint Test C.
C1935
Chime Circuit Failure
U1950
UBP Communication BUS Fault
UBP Communi cation
REFER to Section 418-00.
U2338
Invalid ACM Message Data
SOURCE: The
The lift gate latch is at fault the switch contacts in the latch are worn out replace the liftgate latch and your problem is solved
SOURCE: 2004 Lincoln Aviator Crack in Lift Gate
Take it to a Lincoln dealer. The Lincoln body has a longer warranty than most cars. Your liftgate may not be made of metal, but the through and through failure warranty from Rust could be questionable enough to cover it.
We had a new door and trunklid warranteed after 5 years on our Mark 7. Plus they painted the entire car.
SOURCE: my 2007 Lincoln Navigator power lift gate opens
did lift gate get repaired ? warranty ? what was replaced? $ cost to customer?
SOURCE: The rear lift gate on
POWER LIFT-GATE OPERATION - To open the optional power liftgate, push the button on the instrument panel , press on your five-button key fob (if equipped), or press and release the control located in the left rear quarter panel (Figure B). To unlatch the liftgate glass, push the button ) under the center of the license plate lamp shield, or press on your five-button key fob. Do not open the liftgate or the liftgate glass in a garage or other enclosed area with a low ceiling. Keep clear of the liftgate when operating the rear switch. To open the liftgate manually, pull the handle located on the liftgate to release the liftgate from the vehicle. The power system will take over when you release the handle. To close, make certain the rear window is closed, and then pull down the liftgate a few inches to activate power closing. Closing the gate rapidly or more than a few inches may activate the obstacle detection feature and stop the power system.------------ Also click this link for more help:--- http://technoanswers.blogspot.com/2011/05/power-liftgate-on-will-not-open-on.html ------------ This should help.Keep updated.Thanks.Helpmech.
SOURCE: How can i Open and Close my Lincoln Navigator 2005
As lomg as you have the factory code the procedures are as follows: To unluck the drivers side dorr, simple push in the 5 digit code. If you want to unluck the other doors & liftgate, after you push in the 5 digit code and the drivers door unlocks push the 3/4 button within 5 seconds and if you want you can open the liftgate window by pushing the 5/6 button within 5 seconds. If you want to lock all doors and liftgate, after the drivers side door is closed you can push the 7/8 & 9/0 button at the same time and all the doors & liftgate will lock. As far as the sliding door, no the keypad cannot be used for that. the only other function I believe you can do with the keypad is to activate or deactivate the autolock & you can also store a personal 5 digit code as well. This should be in your owners manual if you have one. If you do not and would like a copy, you can email me at [email protected] with your make, model and year and I will be happy to email you a copy. I hope this helps and good luck.
Click the help link below:---
LIFT GATE / TAIL GATE ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/liftgate-will-not-open.html
These will help.
Thanks.
