Sony C6502 Xperia ZL Android Quadband Unlocked GSM Phone SIM Free Logo
A
Ariel Orlando Jara Garcia Posted on Jan 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm chargin my ZL xperia sony and turn on a red led in the bottom of the cell phone, this is how supossed to be charging? i can nott turn in on, i replaced the charge center cause it was damag
I'm chargin my ZL xperia sony and turn on a red led in the bottom of the cell phone, this is how supossed to be charging? i can nott turn in on, i replaced the charge center cause it was damaged
Rani wadia
Level 3:
Master:
  • Sony Master 996 Answers
  • Posted on Jan 23, 2015
Rani wadia
Sony Master
Level 3:
Master:
Answers
996
Questions
5
Helped
417128
Points
2461
Change battery due to very low charge position
5 Related Answers
Anonymous
  • 470 Answers
  • Posted on Mar 04, 2009
SOURCE: Phone died
its not dead yet my dear, the CPU are defected,, you must go it to the technician, cuz its difficult for you to repair it by tour self,,
Anonymous
  • 95 Answers
  • Posted on Jun 06, 2010
SOURCE: sony erricsson W595 phone doesn't recieve SMS but can send SMS
You are using a wrong charger that is not original. Please change the charger or use a universal charger, you may damage your phone if you insist
Anonymous
  • 21 Answers
  • Posted on Dec 02, 2010
SOURCE: hello. my problem is all
this is sme serious sh*t im just kidding download sonyericsson update service run the program and it should guide u how to update your phone firmware and see if your battery i ok like change into another 1 if u have at home or ask friend tolend u his and see if it still occurs problems with the phone
kalambas82
kalambas82
  • Posted on Jan 31, 2014
SOURCE: looking for unlock code imei 354807053499919 sony xperia tipo phone?
354457053730697
Harrie
  • 6746 Answers
  • Posted on Jan 17, 2015
SOURCE: my sony xperia phone want charge
Could be a bad charger, bad cable, or a bad connection in the phone. Sometimes the usb connector in the phone has a little dust in it, Always make sure the connector is clean and does not have any debris in it.
tip
Solve Xperia Zl Sudden Death Issued
Just want to share with other when have some problem with xperia zl.
The problem is some people call "Sudden Death", no sucessfull to start (ON), only appear at display SONY logo and next will be OFF.
I just facing this problem with my xperia zl, and try also myself to find the problem in internet but no answer even with google. And I just try buy new battery for replacing. do replacing by myself.After replacing with new battery taaa'daaaaa, my xperia zl is working back as well. Perhaps with my short posting can help each other which have some problem with xperia zl.
I understand to replacing this battery is not easy. but you can find the link below to show how to dissasembly your xperia zl.
Hope you can solve the problem as me also. Do it carrefully and good luck.
Solve xperia zl issues sudden death
1helpful
I change the charge center from my celphone ZL xperia sony but it is not charging anymore in the pc, send me the next msg: "Power Surge on Hub port" why is this happening?
Be aware not all USB ports from a PC do give 5 Volt. And even when they do they not all can deliver the norm, 500 mA. Your phone needs 5V and the 500 mA to charge. So when it charges normal on an external charger, check all USB connectors on the PC for the correct power. When your phone also does not want to charge on the external charger, check the cable and the connectors. Connectors must ne clean, A cable is not allowed to have a broken wire in it. If you don't know how to check, just use a new cable.
Problems with t- mobile / unlock/ sony xperia zl can't receive pictures on t-mobile plan
It is probably due to your phone being factory unlocked so there are no provisioning setting applied to the phone when shipped. When you put a new SIM card in the phone the phone asks you if you want to download internet & MMS setting but I think if you go to Settings > there is an option for downloading provisioning setting from your mobile operator( sorry I can't remember exactly where in the settings menu they are it has been a while since I had this phone and it will probably be something like "MMS & internet settings".)
What is the unlock code for my Xperia ZL
Each Sony Xperia ZL mobile phone has an unique unlock code. You can get the unlock code for your phone from TheUnlockSpot.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code.
Jul 01, 2013 • Cell Phones
Unlock my Xperia zl. Easy method needed
You can unlock your Sony Xperia ZL using unlock code which is very easy and safe. You can get the unlock code from TheUnlockSpot.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your phone.
Jun 29, 2013 • Cell Phones
I have Xperia X 10 mini from Sony Ericsson. I left it charging overnight as I do every night since I've got it. And today when I woke up, I took the phone and instead of it being fully charged and
Chances are your phone got too hot during the night and overcharged the Lithium Ion battery. If those batteries are exposed to too much heat then they won't have the battery life they used to have. You need to purchase a replacement battery or contact your wireless carrier to see about getting another one.
Charging prblem sony ericson xperia x10 red light blinking then stop
do you know anyone that uses a Sony Erricson Xperia X10 phone? If yes, borrow the battery and test it with your phone. If your phone turns on with the borrowed battery, then this confirms that it's a charging problem.
Read my tip on the below link, to diagnose and solve the problem.
Click here: http://www1.fixya.com/support/r8742993-phone_charge
If the contents in the above link doesn't help, please let me know for further assistance.
Regards.
Walesarumi
16helpful
2answers
My phone is sony ericsson xperia x10 mini pro, i have kept it for charging after few minutes red color light is blinking and it is not turning on, i have tried removing battery, sim and memory card, but...
My phone is sony ericsson xperia x10 mini pro, i have kept it for charging after few minutes red color light is blinking and it is not turning on, i have tried removing battery, sim and memory card, but still th problem is same. please help me
Top Sony Cell Phones Experts
Aron
ADMIN Eric
ADMIN Eric
NOEL
NOEL
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
