20 Most Recent Sony ST21i Xperia Tipo Black Questions & Answers
i forgot my pattern fo my cell phone sony xperia miro . now they ask to answer the question security but i also forgot . what should i do ringt now ? please help me .
Sony ST21i... | Answered on Mar 13, 2018
you have to go local store to purchase cheaper spear parts if you send me your address I can help you to which market you have to go for cheaper spear parts
Sony ST21i... | Answered on May 20, 2017
Download and install Sony's pass code remover on your PC. Connect your device and follow the prompts.
Sony ST21i... | Answered on Jun 14, 2015
What is your issue? Please explain.
Sony ST21i... | Answered on Jun 11, 2015
Usually after entering the incorrect pattern five times it will lock up for 30 seconds, but it will also provide an option on the bottom of screen that says "Forget pattern?" You must enter your User name and password to reset the pattern.
Sony ST21i... | Answered on May 11, 2015
The range of possible root causes is huge, it is almost impossible to tell exactly what might be the problem. Before getting the device to Sony for check, i would simply try to reinstall the Operation system on the phone with the help of a pc software called Sony Update Service. This is my only guess or advise.
Sony ST21i... | Answered on Jun 20, 2014
Use Sony's PC companion(Find on there website) to do a factory restore(You will lose everything saved on the phone)
Sony ST21i... | Answered on Jun 09, 2014
what kind of problem are u having with this device? you didn't explain in your post.
Sony ST21i... | Answered on Jun 02, 2014
goto settings then tap on backup& reset. Choose the option you want.
Sony ST21i... | Answered on May 30, 2014
Remove battery, sim, sd card, and leave for 15 minutes. Place everything back in and restart. If that doesnt work, it might need software upgrading.
Sony ST21i... | Answered on Mar 22, 2014
I forget my password and I drawn my password 6 time now it locked my phone model no micromax a89 plz sotout my problem
Sony ST21i... | Answered on Feb 25, 2014
You can not unlock password but if your phone is locked and not rooted, you can update your phone's software by Sony Update Service.
Sony ST21i... | Answered on Feb 10, 2014
Did you check restarting your device? It happened with me also but the restart worked fine. If this does not work then try to put other sim card and check. If it happens again try resetting your device.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sony ST21i... | Answered on Feb 02, 2014
If you are connected to the internet (via Wi-fi or your mobile data), you can access your phone after a few unsuccessful attempts by typing the password from the Google account assocciated with the phone (it will prompt that option). If you are offline, then the only way to reset the unlock pattern is by doing a factory reset from Recovery. Check this video: HOW TO HARD RESET WIPE DATA FACTORY RESET MANUAL RESET ON SONY XPERIA...
Sony ST21i... | Answered on Jan 31, 2014
Sony ST21i Xperia Tipo Black Logo
139 questions posted
Top Sony Cell Phones Experts
Robert Lurer
Level 1 Expert
Marvin
Marvin
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Sony Cell Phones
  • Sony Cell Phones
Most Popular Question
pin amp password unlock pattern solved
  • Cell Phones
