Try that video manual:
https://www.youtube.com/watch?v=PEnGZYFXX0w
I often use VPN for one reason or another and I can say with confidence that VPN is not a lie. They protect you from leaking personal data, such as MAC addresses and IP addresses, to the public Internet. This is very important for operational security, regardless of whether you are engaged in hacking or transmitting confidential data. This is why I recommend using a VPN. I know one top with a good VPN https://topvpn.tw/what-is-vpn-and-why-you-need-it
Connect to WiFi.
Tap General>Network>VPN>
To make a new vpn connection in your iOS device you need to do the next:
Once you have created vpn connection you can switch it on and off on the main settings screen.
Server address must be exactly as in your account data (without http://, www or any other symbols)
Sahrzad VPN How to Setup Guides
Connect to WiFi.
you can try these settings I've used before:
Add VPN Connection. chose PPTP.
Give it a name under description.
Encryption Level:Auto
Send all traffic: ON
Proxy: Off
RSA SecurID: OFF
Here's the part that differs from the VPN I personally set up.
Server: enter the IP address of the VPN Server. this is specific to you, as to what server you want.
Account: Enter username and password to log in. If this VPN is for school, it would be your school username and school password you normally use.
The VPN at my school worked when I connected to their wifi and then turned on the VPN. for added information.
