Model no adr6400l, it not work on reliance cdma sim
SOURCE: Can i use the HTC
Sorry!!!!!!!!!!HTC EVO 4G model mobile CAN BE unlocked...But it's IN CDMA Network Lock So that Not able to UNLOCK..Basically any Mobile locked to CDMA network Cannot be Unlocked,But the HTC EVO 4G locked to GSM network means yes Easily Unlocked from the Network LOCK,get the Unlock code here
http://www.prounlocking.com/htc-evo-4g/rs8wp9/ and we can Unlock the mobile by following the Unlocking Instructions.
SOURCE: Can HTC EVO 4G smart phone be used in India on
you can unlock your phone and use it to another network ,but you want cdma services available in specified model , you can use it for gsm after unlocking , if you want to unlock ,you can try codes here http://www.onlinegsmunlock.com/htc-smart/rs7wp9/
SOURCE: can my htc droid eris from verizon work on
If you go here: http://b2b.vzw.com/international/Roaming/Asia-Pacific/India.html#network you can see that Verizon does have roaming agreements with CDMA providers throughout most of India, so I think your phone will work just fine.
Before you go, you need to dial *611 from your phone and have them activate International Roaming on your account. The rates are available on the link above, and they are quite expensive, so be aware of that before you go.
You should probably also disable Data Roaming on your phone before you go to avoid a massive bill, international data is extremely expensive.
SOURCE: Can i use HTC EVO 4G Smartphone on Reliance CDMA
Yes, It can be "unlocked" and you can make it work on Reliance CDMA network. I just got my phone unlocked and using it on Reliance Network. Go with a reputed dealer who could unlock it; don't try doing it by yourself. I got it done from a guy who was located in Delhi via remote access.
