Fujitsu Siemens Amilo PA2510 Laptop Universal AC Adapter 18-20v (AC22VPNXQ7J23) Logo
s
samuel otsiabah Posted on Nov 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Amilo pa 2510 will not turn on when i press the power button.two flash will come and go on the indicator light .what might be the problem
BobLC
Level 2:
Sergeant:
  • Expert 239 Answers
  • Posted on Dec 03, 2014
BobLC
Expert
Level 2:
Sergeant:
Answers
239
Questions
0
Helped
66389
Points
690
Try taking out and reseating the ram sticks - if that doesn't work there is probably a motherboard fault.
you could also try asking on fujitsu siemens forums
Amilo pa 2510
It could be anything, Start with the basics. You may have a power problem Try removing the battery, and run with just the supply. Is the supply OK? Is the battery charging?
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
1helpful
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 • Cell Phones
1helpful
Unit receives power but doesn't turn on. does not respond when power button is pressed.
Do you get any indicating lights at all? Test the charger to make sure there is the right voltage coming out of the charger with a multimeter.
1helpful
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
3helpful
When I turn on my Canon i560 printer the light blinks orange and green and will not print anything. I've tried to turn it off and on, unplug it and nothing seems to be working. What can I do to fix it?
power button.)
2helpful
On Canon S9000 A3 inkjet printer error light flashing to indicate 'waste ink tank nearly full'. Can I fix this myself?
1. Turn off power.
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let the
Resume button go.
4. Press Resume button 2 times then let both
buttons go.
5. Green light will flash then stop blinking.
6. When Green light is solid, press Resume button
4 times.
7. Press the power button and the printer should turn off. If not, press the Power button 1 more time.
8. Done.
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
