When I pull the fuse from the fuel injection.why does the engines throttereturn to normal. Then it throttles high again? I also found a vacum hose loose from where it should be, but i cant find where it go.
SOURCE: I have a 2004 landrover discovery, where is the
As a Land Rover Tech I can tell you that it is true that there is no filter on the series2 there is a small screen at the bottom of the pump pickup that acts as a filter,If you feel this is clogged you can remove the pump by pulling up the rear cargo area carpet as recommended above then just use break clean to clean the screen.Make sure you replace the pump gasket as a faulty gasket will cause a check engine light and a little trick I use is to put a small amount of vaseline on the gasket to ease installation.Also a quick note on series 1 filters is that the lines usually cease up causing the connections to break or damage when removing.I highly recommend getting the repair kit available at the dealer or rovers north before attempting to replace the filter .
BUT IN REGULAR 2004 lan-drover discovery there is fuel filter located.
Removing the fuel filter
The fuel filter is located on bulk head, to left hand side of the engine.
1: Start by cleaning the area around the filter head.2: Place a container beneath the fuel filter to catch any spillage.3: Loosen the bleed screw using a 10mm spanner4: Unscrew the drain tap on the bottom of the filter until the fuel starts coming out into your the container.5: Once all the fuel is drained from the filter, unscrew the whole filter assembly.
Fitting the new fuel filter
6: Clean the seal & seating on the new filter.7: Put a small amount of fuel around the rubber seal to lubricate it.8: Screw the new filter onto the filter head and tighten by hand.10: Tighten the bleed screw.11: You can now crank the engine until fuel is drawn through the system and the engine starts.Job done!
This will help. Thanks please keep updated.please do rate the solution positively
.thank you for using fixya
SOURCE: landrover discovery fuel pump
Turn the key on for 2 mins then off. about 5 Times to prime the pump and the system. My TD5 solution
SOURCE: Landrover discovery wont start but battery is good
This usually is the starter, especially if your truck has had an oil leak going for a while as the oil will run down into the starter and cause it to intermittenly fail. Also check your battery terminals and make sure you have a good connectivity.
SOURCE: need head bolt torque settings for 200 landrover discovery 4.0 liter 241 cu.in.
Stage 1 20nm
Stage 2 +90 degrees
Stage 3 +90 degrees
SOURCE: Landrover discovery Td300 1998
the rev counter on the 300tdi disco takes its speed signal from a wire connected to the back of the alternator (single spade type connector) this wire usually breaks rewire and should be ok
cruise faults are usually caused by a vacuum pipe splitting check all the vac pipes to the cruise control actuator in the engine bay and at the brake pedal switch of end are split cut off and refit pipe
