Nikon COOLPIX P6000 Digital Camera Logo
a
annie Dent Posted on Oct 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my Coolpix P6000 cancel out all my menu settings when I change the battery?
Why does changing the battery disable all the menu alterations and user settings I save on the p6000. Is there a way around this problem If I change the battery on this camera all the menu settings including the user settings and clock/date etc return to a default (factory default I imagine) and I have to reset the whole lot. Surely there must be a way around this but I can't find it. Can you help me please
Steve Zimic
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 27, 2021
Steve Zimic
Contributor
Level 1:
Answers
Questions
0
Helped
405
Points
The only way around the problem is to plug the camera into the charger when changing the battery.
Jim Jordan
Level 3:
Master:
  • Nikon Master 442 Answers
  • Posted on Jan 05, 2015
Jim Jordan
Nikon Master
Level 3:
Master:
Answers
442
Questions
0
Helped
114928
Points
1360
It sounds like the date memory battery (if your camera model has one) is dead. If you don't see info in the manual, look for a tiny slot in one of the camera's access points like where the SD card or larger battery is and see if you see it there. It will be a thin, tray that contains a button battery. If there isn't one then the camera uses an internal battery that would have to be replaced by Nikon.
2 Related Answers
Anonymous
  • 11967 Answers
  • Posted on Aug 27, 2009
SOURCE: Each time I remove the battery from my Nikon
Go to the support section of the Nikon website and e-mail one of their tech people with your problem...I'm sure they can solve it.
Anonymous
  • 11967 Answers
  • Posted on Aug 13, 2010
I probably need more details but, it sound like when you remove the battery to recharge it, the clock loses any power it had. Most people have a second battery. When the first battery begins to lose power, they insert the fully charged battery so the clock is only without power for a few seconds. Try that.
I replace new battery for my nikon coolpix p600 but still can not switch on. Please tell me how to fix this problem...thanks Larry
You will have to tell us what happens when you put a EN-EL23 battery inside the camera and you hook it up to the charger or USB. If the charger or USB is hooked up the Camera will Turn ON. The POWER LED will be GREEN. Another LED on the camera will FLASH GREEN. If this happens when you charge it you are halfway home. Change it until the flashing LED turns off. This means Battery is FULLY changed. Then REMOVE the USB or CHARGER and try to turn it on.
1helpful
Their is a small internal battery that holds the time inside the camera, Sounds like the internal battery is dead
Factory reset for nikon P6000
Try removing the battery for 15mins. replace the battery then go to the camera's menu to set the Date & Time.
How di i turn the date stamp on for a nikon coolpix p6000
Press the MENU button to bring up the main menu. Press cursor-left to get to the tabs. Use cursor-up/down to select the Setup tab (the wrench icon). Press cursor-right or the OK button.Use cursor-up/down to select "Date Imprint" and press cursor-right. Make your selection, press OK. Press MENU to exit the menus.
Full details are in the "Basic Camera Setup: The Setup Menu" section of the manual (starting on page 159 in my copy). If you need a manual, you can download one from the manufacturer's web site at
http://support.nikontech.com/app/answers/detail/a_id/16031
I've only had my Nikkon CoolPix for a month with only 100 pictures and keep getting the battery exhausted. I keep changing the batteries, but I keep getting the same message. Helo!
The Nikon CoolPix 3200 has an unusual battery selection AND also needs the type of battery being used to be selected in the set up menu. The default is Alkaline, if you are not using Alkaline this function may be part of your rapid discharge. What I would suggest is to switch to a "good" set of Ni-MH batteries, generally these can be bought as a set/kit with a charger. If you have a manual what I'm referring to is on pages 18 and 19. For changing the setting for battery type can be found on page 96. The battery choices for this camera can be confusing to anyone. Happy Holidays from Robert in Canada
1helpful
How do I undo a reformat on an HP? My HP was reformatted and I need to return it to the previous state. Already tried system restore, but prompt said there is no point to restore to. Is there a way to...
Troubleshooting
Accessing Computer Setup
The information and settings in Computer Setup are accessed
from the File, Security, Tools, and Advanced menus.
1. Open Computer Setup by turning on or restarting the
computer. Press f10 while the F10 = Based Setup message is
displayed in the lower-left corner of the screen.
To change the language, press f2.
To view navigation information, press f1.
To return to the Computer Setup menu, press esc.
2. Select the File, Security, Tools, or Advanced menu.
3. To exit Computer Setup, choose one of the following:
To exit without saving any changes, use the arrow keys to
select File > Ignore changes and exit, and then follow
the instructions on the screen.
To exit and save all the settings you have entered, use the
arrow keys to select File > Save changes and exit, and
then follow the instructions on the screen.
Your preferences are set when you exit Computer Setup and take
effect when the computer restarts.
Computer Setup Defaults
To return all settings in Computer Setup to the values that were
set at the factory:
2. Use the arrow keys to select File > Restore defaults.
3. Select the Restore Defaults check box.
2–2
Maintenance and Service Guide
Troubleshooting
4. To confirm the restoration, press f10.
5. Select File > Save changes and exit, and then follow the
When the computer restarts, the factory settings are restored, and
any identification information you have entered is saved.
Selecting from the File Menu
Table 2-1
File Menu
Select
To Do This
System Information ¦
View identification information about the
computer and any battery packs in the system.
View specification information about the
processor, memory and cache size, video
revision, keyboard controller version, and
system ROM.
Save to floppy Save system configuration settings to a diskette.
Restore to floppy Restore system configuration settings from a
diskette.
Restore defaults Replace configuration settings in Computer Setup
with factory default settings. (Identification
information is retained.)
Ignore changes and exit Cancel changes entered during the current
session. Then exit and restart the computer.
Save changes and exit Save changes entered during the current session.
Then exit and restart the computer. The changes
you save are in effect when the computer restarts.
2–3
Troubleshooting
Selecting from the Security Menu
Table 2-2
Security Menu
Select To Do This
Administrator password Enter, change, or delete an HP Administrator
password.
Power-on password Enter, change, or delete a power-on password.
Password options ¦
Enable/Disable stringent security.
Enable/Disable required password on restart.
DriveLock passwords Enable/disable DriveLock; change a DriveLock
user or master password.
DriveLock Settings are accessible only
when you enter Computer Setup by turning
on (not restarting) the computer.
Smart Card Security Enable/disable power-on support for smart cards.
This feature is supported by select smart
card readers only.
Embedded Security ¦
Enable/Disable the embedded security chip.
Restore embedded security chip to factory
settings.
Enable/Disable power-on authentication
support.
Enable/Disable automatic DriveLock.
Reset power-on authentication credential.
Embedded Security settings are accessible
only if the computer is equipped with an
Device security Enable/Disable devices in the system.
Enable NIC for inclusion in MultiBoot.
System IDs Enter user-defined identification values.
2–4 Maintenance and Service Guide
Troubleshooting
Selecting from the Tools Menu
Table 2-3
Tools Menu
Select To Do This
HDD Self Test options Run a quick or comprehensive self-test on any
hard drive in the system.
Battery Information View information about any battery packs in the
computer.
I have been given a Coolpix P6000 which I am still experimenting with. My latest pictures contain some images which have an NRW extension instead of JPEG and these pictures cannot be printed. How can I...
NRAW is a RAW image file taken directly from the the sensor & is not processed by the camera. RAW files can be edited in photo editing software. If you want camera to record JPEG files change your [IMAGE QUALITY] setting to [FINE], {NORMAL] or [BASIC].
or to record image in both formats as RAW & JPEG use [NRAW+FINE] etc.
Hope this helps you ;)
Lost my Users Manual for Coolpix P6000. Unable to download.
http://support.nikontech.com/app/answers/detail/a_id/13948
http://www.nikonmall.com/category/instructionmanuals
Wrong batteries settings prevents access to menu
Charge fully the batteries you have, to prevents the camera distinguish the type of batteries (maybe the camera senses the charge), turn on the camera and you will have access to the menu to set up the batteries type correctly, that´s all.
I am unable to select the auto bracketing on my Nikon Coolpix P6000. I went to the camera shop i bought it from, but the guy had the same problem. It does show in the menue but i am unable to select it....
Check page 143 in your manual. Auto Bracketing does not work when in Manual mode or when NRW is selected by itself or in conjunction with Fine, etc. Hope this helps. I'm trying to find a way to be able to enable Auto Bracketing in Manual Mode.
...Derek
801.305.3606
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
