Your Digital Watchdog dw-vf162t should be reset according to proper instruccions. If you don't have the manual, you shshould contacte provider Contacts Digital Watchdog
When you mean reset the Kyocera domino S1310, I do have a link for you.
Please don't let us guess. You have all the details. Be as clear as possible and put in as much as possible details you have. Hard Reset for Kyocera Domino
I found the following for DVR Vmax Flex: Reset procedure is as follows, Press and hold the OK button on the remote for 45 seconds, it will beep many times, a screen will pop up and ask you to reset, select YES. The reset will default it to factory, which is No Password at all. If this is not the info you're after, you can choose a method to contact Digital Watch Dog shown on their webpage:
http://digital-watchdog.com/
I've never seen a watchdog.tion error but watchdog errors can be set up on some CMOS when the 5v power from the power supply is bad. I can't find anything on your specific error tho but I would try a different Power Supply Unit.
I would need to know the serial number of the unit.
You need to press 2 buttons on the remote then enter a five digit number to enter the service menu to reset the lamp counter.
*#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast samsung mobiles
*#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN *#9998*837# Mobile Software Version *#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version
For Mobile phones SGH (R210, T100, A300...) if Samsung code is in format *#9998*xxx# try write in this *#0xxx#
SGH-600 SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking: Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged
hi
try these codes
*#06# Show IMEI
*#9998*872# Diag
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
SGH-600
SGH-2100
Unlocking:
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
