Is there a fuse or something that needs to be replaced? I have tried other power cords and still nothing. Can this machine be saved?
SOURCE: Replacing bobbin case on the Elna 6005
I messed with it for about 2 hours trying different ways the under neath part of the bobbin was facing. I just gave up put it all back together and turned off the machine and turned it back on. It worked, I don't what I did but it worked. thanks any way.
SOURCE: Have lost the power cord for Elna Air Electronic
You should be able to find the right power cord at
http://sewingpartsonline.com/search.aspx?find=elna+air+electronic
Select your model number from the list.
SOURCE: Elna 6003 just stopped working
I need a manuel for a Elna 6003 quilters designer where can a purchase one???
SOURCE: need a copy of the service manual for elna 6005 .
There is below the link to ELNA 605 User's Guide:
http://safemanuals.com/user-guide-instructions-owner-manual/ELNA/6005-_F
SOURCE: I have an Elna 6003Q
some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
