Question about Elna Sewing Machines
Service manual elna 722010 sewing machine
Hi, I am looking for a service manual not instruction manual for a elna supermatic 722010 sewing machine
Posted by Jenny Lowe on
  • Anonymous Mar 18, 2014
    Hi, I need a manual for a Mundlos "fantasy" sewing machine
Anonymous
    New Friend:
Www.whitesewingcenter.com has the manual for an Elna 722010.
Posted on Mar 27, 2010
Where to get a user manual for Elna Supermatic 722010 sewing machine - vintage 1963-1964
Hi Beverly,
My suggestion is that you join up the Yahoo group called "Elna Heirlooms" you'll find lots of very helpful fellow supermatic owners there and probably what you are looking for too. Here is one page from the manual for threading the bobbin into tension, once you've mastered this on the Elnas, its the same for all the Swiss ones.
Yes, top threading is important, you need to get the thread into the tension discs and also the take up lever. Have you cleaned out the tension discs too? these do get gummed up with fibres and dye particles sometimes. Just turn tension down to zero and "floss" between discs with the selvage edge of a clean piece of waste cotton fabric.
Might see you over on Yahoo, several of the members there are really knowledgeable on these great machines.
cheers
Tallygirl
Oct 13, 2011 | Elna 2007 Mechanical Sewing Machine
I have lost my manual for my elna supermatic seger, where can I find one?
Hi Glen, not sure if you mean sewer, or serger. The Elna Supermatic sewing machine manual is available at this link: http://www.clawges.com/sewing/Elna_manual/index.html
Trust this is what you are looking for.
Sep 01, 2011 | Sewing Machines
Do I need the model no. to order a manuel. For the Elnasuper is this a model no. 7131 ?
The Swiss Elnas included several models called "Supermatic" and SU so it is good to identify your machine by the model number.
If you look at the Identification plate on the machine it should have a 2 digit model code and a serial number.
However, one of the very early machines was called a 722010.
If you browse www.whitesewingcenter.com you may find your manual available there. He is the Swiss Elna guru for old parts and accessories.
Aug 22, 2011 | Elna Sewing Machines
On my elna supermatic 722010 sewing machine, the thread makes the bobbin pop out and the thread get tangled underneath. I have had it fixed twice, which is expensive. Should I just get rid of it and buy...
not unless you can find another swiss elna, like star series su. check bobbin in right way, holes on top to wind and load. you havent bought anothet type bobbin??? go to www.arizonaexpressionz.com and download a manual for supermatic. then read bobbin winding and threading carefully and rewinf bobbin and thread up again. make sure thread goes into tension spring all the way. bobbin should turn anticlockwise when yoou pull thread. also please brush clean bobbin holder area and check for any threads caught there. now a drop of quality clear machine oil in middle hole and gently run for 30secs to work in. do this every time you get your machine out. there are several oiling points shown in manual. oil them. these machines are quality but yours may need love tlc from a elna tech especially if it has not been serviced in a while. but a well maintained elna will out stitch a new plastic machine any day in my humble opinion. if you want to join yahoo group elna heirlooms, experts who service their own and share photos info manuals and love these vintage classics.
Jun 16, 2011 | Elna Sewing Machines
I was given an Elna Supermatic 722010 and am not sure how to wind the bobbin.
A link to a supermatic manual is here
http://www.arizonaexpressionz.com/elna_instruction_manuals/Supermatic.pdf - I suggest you download this and print it out as this machine is over 50 years old now and manuals are scarce.
Disengage the clutch by holding the outside of the fly wheel and turning the inner knob of the wheel towards you.
You need to take the thread from the spool across to an eyelet on top left, then back to the bobbin winder, up through a hole in the top of the bobbin and hold the thread tail. Flick the bobbin across against the stopper. Now press the presser foot or knee control to start the motor. Hold the thread tail until youve got coverage across the bobbin enough to hold the start, then stop winding and cut the thread tail with scissors. Now continue winding but put the handle of your scissors on top of the thread spool to stop it bouncing and ensure your thread winds smoothly and under tension.
Watch the bobbin fill and give the thread a nudge to fill top and bottom as well as the middle evenly, you want a nice even wind. Fill to 3/4 and stop, flick bobbin back off the stopper, then cut the thread. Remember to re-engage the clutch by reversing the first step.
This is a lovely heirloom Elna machine - you need to thread the bobbin as the manual describes and get the thread into the tension spring. Please read the manual information on oiling too, this machine needs to be oiled on the red spot locations every time you use it according to the manual, use good quality clear sewing machine oil for this purpose.
Oct 21, 2009 | Elna 2007 Mechanical Sewing Machine
What bobbin size for elna supermatic 722010 Can I purchase metal bobbins for this machine at a Joannes? or ? Is there a staner bobbin number or size to ask for?? [email protected] The Elna I have came with ONE...
Elna Supermatic 722010 is a very vintage elna and would take the metal 7 hole dished bobbin like this.
Don't try to use any other bobbin in it, and always load and wind with the holes on top.
You can still buy these; one supplier is sewingpartsonline, here is like to the item
http://www.sewingpartsonline.com/bobbins-elna-426000-10pk.aspx
Aug 17, 2009 | Elna Heirloom Edition 6005
Extra discs for an vintage Elna Supermatic plus pressor feet.
Try the usual eBay route, but also approach any Sewing Repair shop as they often acquire odd bits from old machines....We had 9 disks for a lady with an Elna SU only last week, all from a machine traded 2 years ago and really beyond resale.
Aug 02, 2009 | Sewing Machines
Sewing Machines Logo
3,741 people viewed this question
Top Elna Sewing Machines Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
