Polycom SoundPoint IP 320 SIP IP Phone Logo
A
Anonymous Posted on Oct 03, 2014
I have 25 SIP lines my question is, Why sip phone delay dial to IP phone in 4 to 5 seconds? But, if I used auto dial feature on SIP Phone, IP Phone ringing immediately
Joe Lane
Level 2:
New Friend:
  • Expert 43 Answers
  • Posted on Jun 17, 2015
Joe Lane
Expert
Level 2:
New Friend:
Answers
43
Questions
0
Helped
33753
Points
122
Dial plan.... try pushing # after the number to make call without the delay
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jun 04, 2009
SOURCE: failed to get boot parameters via DHCP
You didn't provide any information about your network which is ALWAYS required to provide any type of help, not to mention a solution.
"Failed to get boot parameters via DHCP, xxx seconds until reboot" simply means that the computer isn't getting an IP address from your router. Setting up your router is another entirely separate topic.
This is pretty simple though, one of three things is happening:
1. Your router is not properly configured to provide DHCP to the phone.
2. Your network cable is bad.
3. Your phone is bad (most likely the RJ45 port since the phone seems to work otherwise).
You can check for bad ports or cables by checking the port status within the router. If the port is lit up, most likely the cable and phone port are fine. This is not 100% though, replacing the cable should always be a consideration even with a lit port.
Testimonial: "thank you"
A
Anonymous
  • Posted on Sep 27, 2009
SOURCE: Making a Polycom SoundPoint 501 work on an Avaya IPO
As you have probably found, SIP phones are not supported until R5, which just came out.
Anonymous
  • 95 Answers
  • Posted on Dec 22, 2009
SOURCE: what is the default password for Polycom
Default Passwords:
To get into the web interface, the default username/password is "Polycom"/"456" (Note that this does not work with Safari 1.2.2.)
To get into the Admin interface on the hard phone, the password is "456". (Prior to v1.3.1, the web interfaces to the phone uses "Polycom"/"SpIp" as the username/password.)
The "user password" (not used much) defaults to "123".
To reset a lost admin password to default: at phone boot, during the 5 second countdown, push/hold 468* on the phone. Enter the phone's MAC address as the password. This will reset network info but keep peers loaded. Tested on Soundpoint IP 650.
Testimonial: "Thanx a lot. Although I had managed to find the password for console but the web interface password was still missing. :-)"
Anonymous
  • 11 Answers
  • Posted on Jan 12, 2010
SOURCE: Polycom IP 330 SIP C Will not boot up
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Anonymous
  • 11 Answers
SOURCE: i am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
I have polycom SoindPoint 301 and i would like to use as SIP to one of the VoIP providers. I dont have asterisk in my network and i would like to connect it directly to the VoIP provider. So there is no...
1st. Get the IP address of the phone. and type that into browser.
*- default user: Polycom / password: 456
*- Under menu SIP, type in your voip provider
*-Under menu LINES type in user info and "secret" should be your password.
Make sure your ports are open (SIP is usually 5060) you can change it in that same config screen.
How do I cahnge the ip address on the linksys spa941 when it failed to registered: it is not picking up ip address from the switch.it was working before change the switch
Confirmed modelLinksys IP Phone SPA941 and SPA962 with SPA932
Linksys IP PhoneThis document explains how to use Brekeke SIP Server with the Linksys IP Phone SPA hard phone .
The Standard features include two active line appearances, call forwarding, redialing, speed dialing, transferring calls, conference calling and accessing voice mail. For more information regarding this product please go to www.linksys.com
Configure Linksys PhoneSet up your Linksys phone with a fixed IP address (e.g. 192.168.0.15) and subnet mask (e.g. 255.255.255.0).
Once the IP address is configured you can access phone webpage by its IP from web browser (e.g. http://192.168.0.15). Network SetupClick on "Admin Login", then select “System" tab. Sign Static IP, Gateway and NetMask.
Use the following data as an example
  • Static IP: Linksys phone IP (e.g. 192.168.0.17)
  • Netmask: 255.255.255.0
  • Gateway: not needed if SIP Server is in the same LAN as Linksys phone
  • Click on [Submit all changes] button now to reboot you phone,
    or after whole setup is finished
Phone ConfigurationSelect tab Ext1 or Ext2 and enter SIP server information and sign extension number
Use the following as an example to complete the phone configuration.
  • Proxy and Registration:
    • Proxy: Brekeke SIP Server’s IP address (e.g. 192.168.0.69)
    • Register: Yes
  • Subscriber Information:
    • Display Name: extension number or Name (e.g. 400 or Alice)
    • User ID: extension number (e.g. 400)
    • If user authentication is set on at Brekeke SIP Server,
      type in the same information at Auth ID and Password as what you set at SIP Server side
      and Use Auth ID: Yes
  • click [Submit All Changes] button to restart the phone
phoneconfig.gif Brekeke SIP Server’s Registration PageClick the [Registered Clients] tab at Brekeke SIP Server admintool.
The Linksys IP Phone SPA941 Phone is registered with Brekeke SIP Server.
1helpful
My handy tone-486 box keeps flashing red every 3 seconds and I have no dial tone. My internet works and I have power and a working phone line to the box. Help.
Lifted this straight from the manual:
Button flashes every 4 seconds
(if SIP server is configured)
HT–486 fails to register
So basicly, that means your HandyTone 486 ATA fails to register with the SIP-server. That means you either have not recieved your IP-tele yet, or that your ISP have failed to register you.
2answers
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
2answers
Only one line works
check the ip phone cable and reset the ip phone all setting
1helpful
2answers
Using AVAYA 4610SW IP phone
Answer to the second problem :-
1. The changes in the ring tone has to be made by accessing the Avaya server where the phones are registered.
2. Log in to the avaya server...... enter change station <station number> on the command prompt
3. In the personalized ring pattern field, you can select one out of the 8 available options by typing any digit between from 1 to 8.
4. The ring pattern of that particular station will change accordingly.
5. Keep the personalized ring pattern of all the stations different by assigning different digits against this value
I am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
15helpful
4answers
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Update the firmware of D-Link DPH-70s to support SIP protocol
this phones doesnt got support for standard SIP protocol, so its not supported by any major voip provider.
Top Polycom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
