20 Most Recent Linksys SPA941 IP Phone Questions & Answers
ask your local admin to remove your phone from coverage path
Linksys SPA941... | Answered on Dec 03, 2015
SPA 941 is a pixel display phone. You can configure it to work with any IP Telephony server like asterisk easily.
1. Press "Paper" Button and press "9". You ll find yourself in network settings.
2. Configure IP address, Subnet mask, Default gateway.
3. Now enter http://ipaddress in your browser
4. Choose EXT1 menu on top
5. Configure the following
Proxy: Your server here
User ID: Enter the phone number (Mostly they are phone nos.)
Password: Enter the password / Secret
Note : depends on your server config you may need to configure some extra informations. Say SIP Port, Preferred Codec, Auth ID etc.
6. Save settings
7. Happy calling.
HTH
-Karthik.
Linksys SPA941... | Answered on Oct 20, 2012
The phone doesn't like a gigabit port on the switch. I changed the port speed to 100 Full Duplex, disabled jumbo frames and the button stopped blinking. Wasn't that annoying as hell?
Linksys SPA941... | Answered on Sep 27, 2011
you can access this phone by using its IP in the web browser and check your settings.you can also contact your service provider.
Linksys SPA941... | Answered on May 10, 2011
you don't need to worry you can restore the setting by using "factory restore" and contact your service provider.
This usually means that the phone is not registered. Have you entered your SIP account credentials and verified that they are correct?
Linksys SPA941... | Answered on May 04, 2011
Press Reply or Accept
I can fix this
Bruce
Linksys SPA941... | Answered on Jan 17, 2011
The are two things you can do to correct this but it will be done by your call manager administrator. He can disable the Voice mail call feature on your profile. He can reload the firmware of your PhoneThis will be able to correct your problem.
Linksys SPA941... | Answered on Jun 10, 2010
Confirmed modelLinksys IP Phone SPA941 and SPA962 with SPA932
Linksys IP PhoneThis document explains how to use Brekeke SIP Server with the Linksys IP Phone SPA hard phone .
The Standard features include two active line appearances, call forwarding, redialing, speed dialing, transferring calls, conference calling and accessing voice mail. For more information regarding this product please go to www.linksys.com
Configure Linksys PhoneSet up your Linksys phone with a fixed IP address (e.g. 192.168.0.15) and subnet mask (e.g. 255.255.255.0).
Once the IP address is configured you can access phone webpage by its IP from web browser (e.g. http://192.168.0.15). Network SetupClick on "Admin Login", then select “System" tab. Sign Static IP, Gateway and NetMask.
Use the following data as an example
  • Static IP: Linksys phone IP (e.g. 192.168.0.17)
  • Netmask: 255.255.255.0
  • Gateway: not needed if SIP Server is in the same LAN as Linksys phone
  • Click on [Submit all changes] button now to reboot you phone,
    or after whole setup is finished
Phone ConfigurationSelect tab Ext1 or Ext2 and enter SIP server information and sign extension number
Use the following as an example to complete the phone configuration.
  • Proxy and Registration:
    • Proxy: Brekeke SIP Server’s IP address (e.g. 192.168.0.69)
    • Register: Yes
  • Subscriber Information:
    • Display Name: extension number or Name (e.g. 400 or Alice)
    • User ID: extension number (e.g. 400)
    • If user authentication is set on at Brekeke SIP Server,
      type in the same information at Auth ID and Password as what you set at SIP Server side
      and Use Auth ID: Yes
  • click [Submit All Changes] button to restart the phone
phoneconfig.gif Brekeke SIP Server’s Registration PageClick the [Registered Clients] tab at Brekeke SIP Server admintool.
The Linksys IP Phone SPA941 Phone is registered with Brekeke SIP Server.
Linksys SPA941... | Answered on Jun 09, 2010
check if you have the ethernet cord conencted correctly from router to VOIP phone
and also check if you have internet conection
Linksys SPA941... | Answered on Apr 28, 2010
You can check your ringing setting and you can reset that also for more ring before go to voice mail box.
Linksys SPA941... | Answered on Mar 30, 2010
There are several factors that will affect or can cause problems in connecting your Roku to your Router.
If you're getting an error message on Roku like 014, 011, make sure to indicate it in your response. Normally, if you're getting 014 message, you can follow these steps:
. A simple power cycle resolves most of the issues. To perform a power cycle, please follow the instructions below:
1. Unplug the power cables from the modem, router and the Roku player.
2. Connect the power cable to the modem (after a minute). Once all the lights on the modem are lit, plug in
the power cable to the router and then to the Roku player.
3. Go to "Settings" and redo the complete Roku setup.
If the issue continues to occur, please try the channel 1 or 3. Should it persist, you may reset the Roku
player. Here is how:
On the back or bottom of the Roku unit, you should find a recessed little hole.
- Use a pin or paperclip to press and hold the button for 30 seconds (please ensure that the power light
blinks while you are holding it down).
The Roku device will reset to default and be ready for setup again.
If the problem continues, please reflash the software via the secret screen:
1. Press the "Home" button for 5 times.
2. Press the "Forward" button for 3 times.
3. Press the "Rewind" button twice.
4. Choose Update Software and the Roku player will then restart.
You can comment your serial number or the error message that you're getting. If your getting 011, just power cycle your entire network. Also, please make sure that you're not connecting the Roku to a Guest network. The speed of your connection matters as well. It should be atleast 1.5mbps.
Linksys... | Answered Yesterday
https://www.linksys.com/ca/support-article?articleNum=140923
Which model?
Go to the Linksys website and download the instructions for your model of extender.
Linksys... | Answered on Dec 02, 2019
Linksys SPA941 IP Phone Logo
23 questions posted
Popular Products
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SPA Linksys
  • SPA Linksys
Most Popular Question
set up linksys spa941 ip phone home
  • Computers & Internet
