Husqvarna "YTH26V54 54"" Briggs And Stratton 724cc 960430111 Riding Lawn Mower w/ Hydrostatic Drive 2012 SPECIAL ORDER*" Logo
A
Anonymous Posted on Oct 02, 2014
Forward is slow
Engine oil level good but hydrostatic drive v slow and gets slower when hot
charles beach
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Husqvarna Master 1,917 Answers
  • Posted on Oct 03, 2014
charles beach
Husqvarna Master
Level 3:
Renaissance:
Answers
1917
Questions
Helped
570519
Points
3010
Need to change hydrostatic fliud and filterthat will take care of it
2 Related Answers
agent91
Ned White
  • 2100 Answers
  • Posted on May 04, 2010
SOURCE: POWER TRAIN
No, It sounds like you are low on oil. there is a fill cap on there somewhere, might be a bolt, plug, but you can check it and fill it hyd oil. I had an old Wheelhorse, never had a problem with the hydrostat, worked great. Check it out, hope this helps.
Anonymous
  • 6468 Answers
  • Posted on Mar 29, 2012
SOURCE: hydrostatic drive gear YTH 1542
for not charging pull the cover off the top of the engine look for damaged wires mice love to eat them going slow i would check the belt for oil or see if its tight
Slow forward drive on hydrostatic mower husqvarva 316 tsx awd
Likely there is air trapped in the system. Try raising drive wheels (safely) off the ground and operating forwards backwards. With minimal load on the hydo pump and motor, the air should purge.
We have a 1986 Cub Cadet Hydro 1210 that won't go forward!
If your 1986 Cub Cadet Hydro 1210 is experiencing difficulty moving forward but works fine in reverse even after changing the transmission filter and fluid, there could be a few potential reasons for this issue. Here are some steps you can take to troubleshoot the problem:
1. **Check Drive Belt:** The drive belt is responsible for transferring power from the engine to the transmission. A worn or damaged drive belt can affect forward movement. Inspect the drive belt for any signs of wear, fraying, or damage. If the belt is in poor condition, consider replacing it.
2. **Check Tension of Drive Belt:** Ensure that the drive belt is properly tensioned. A loose drive belt can lead to slipping and difficulty in forward movement. Adjust the tension according to the manufacturer's specifications.
3. **Inspect Linkage and Connections:** Examine the linkage and connections between the control lever, transmission, and the drive system. Loose or misaligned linkage can result in improper engagement of gears, affecting forward movement.
4. **Hydrostatic Transmission Issues:** Since your Cub Cadet Hydro 1210 uses a hydrostatic transmission, there could be issues with the hydrostatic unit itself. Check for any signs of leaks, damaged hoses, or worn components in the hydrostatic transmission system.
5. **Transmission Oil Level and Quality:** Ensure that the transmission oil level is correct and that you're using the recommended type of oil. Poor-quality or incorrect transmission oil can lead to performance issues.
6. **Air in the Hydraulic System:** If there's air trapped in the hydraulic system, it can cause issues with the hydrostatic transmission. Bleed the hydraulic system to remove any air bubbles.
7. **Transmission Pulley and Sheaves:** Check the transmission pulley and sheaves for wear or damage. If these components are not functioning properly, they can affect the movement of the drive belt.
8. **Check for Obstructions:** Inspect the underside of the mower deck and the drive system for any debris, obstructions, or objects that might be interfering with the forward movement.
9. **Professional Inspection:** If none of the above steps resolve the issue, it might be a more complex problem requiring the expertise of a professional technician. They can perform a more in-depth diagnosis of the hydrostatic transmission system and identify any underlying issues.
Keep in mind that working with mechanical and hydraulic systems requires knowledge and expertise. If you're not comfortable performing these checks and repairs yourself, it's recommended to consult a qualified technician who has experience with Cub Cadet or similar equipment.
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
The Hydrostatic transmission on my Lt150 mower is making a screeching noise when I push on the forward/reverse pedal. The mower will move very slow then stop. It is not the drive belt!
Check trans. oil for debris and quantity. If level is low try topping up first and if this works it would pay to disassemble in the near future, clean the oil filter and fill with clean oil.
Cub cadet i1042 zero turn doesnt seem to want to go forward when turning or even going strait sit moves very slow and when i go up a little hill it stops half way and then creeps up the hill it use to
If it's a hydrostatic transmission, I would have the transmission looked at. You may need to "purge" the system and check the fluid level.
The ones I've done called for the drive disconnects (the rod or lever which allows you to roll the tractor when the engine is shut down) to be in the flow bypass position. They also wanted the wheels off the floor, then the engine to be started, & the direction control to be worked SLOWLY to the front & rear positions 10-12 times. Then put the bypass valve back in its 'drive' position, fire the engine again & repeat the slow cycle of the direction control. The unit SHOULD be quieter now & perform better, but double check the oil level because expelling the air may have dropped it too low.
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
My tractor won't go up any grade or incline.... it just gets slower and slower until it stiops.
HI
Im sure you have a hydrostatic or an automatic forward and reverse right well your ****** is on its way out when it warms up it likes to crawl in this case even if you attempt to check oil or even try draining and putting in different oil its a tough one ****** is expensive
Joe
Joe
1helpful
Mower won't move in forward or reverse, it just makes a loud wining noise. I've had this happen before but I usually can get it moving.
If this is a hydrostatic drive. Check oil level in transmission. If you have been running it low on oil, it may be too late for the hydrostatic drive unit. If it has a drain plug, drain it and change the oil.
1helpful
I have an older weedeater riding mower. I tipped it up on end to do some welding on the frame and some fluid leaked out. I thought it was from the hydrostatic transmision, however the manual says that it...
There is a breather tank or hose on the top of transaxle. Remove back hitch plate from tractor.There is either an allen wrench plug or a breather hose fitting you can remove to add oil to the transaxle. Add synthetic 15w-50 or 20w-50 motor oil,Amsoil,Mobil-1,Lucas oil or Purple power are good brands to use. Do not use hydrostatic oil.it is too thin.Fill to within 1.5 inch from top which will allow air for expansion. After filling, purge transaxle by putting it it in freewheel mode ,run engine at full speed with clutch out and work the drive back and forth between forward and reverse 10 times,then it should be good to go.
Aug 21, 2009 • Garden
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
