SOURCE: Lamp out ...
remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
SOURCE: just replaced dlp lamp
From what I remember, when you turn on the tv, use the remote and when it asks if you replaced lamp say yes.
SOURCE: Replaced Bulb and sill have red lamp light
no you should not feel any click,the lamp plug
slides into the ballast plug in the groves.do not
force it,you could have the plug upside down or
you need to visually see if the ballast plug is
damaged.you may need to replace the ballast if you still are getting a red lamp error on the
front of the tv.
SOURCE: just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
SOURCE: recently my wd-52327 said it needed new
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
