The display screen is blank, won't show settings etc. can't adjust any settings because you can't see which one you are adjusting, doesn't light up. All of the buttons work, plays music, buttons light up in different colors. please help me with some troubleshooting ideas. this is my favorite thing in the world, and has been out of my car for a few years. also someone different put it in this time
SOURCE: How to adjust TIME on Alpine CDE-7856
Once you get the time blinking it is buttons 5 (hour) and 6 (min) that adjust the time.
These are channel buttons on the far right: they are green and are on the bottom edge.
SOURCE: Car Cassette Adapter keeps flipping from one side to another
that stero has a setting to flip the tape over automaticly when the tape is done. it will do this with a sensor on the drive motor for the tape deck there is really no way around this with out modification. i would sugest a good fm transmitter (walmart or best buy about $30.00)
SOURCE: alpine cda-9857r turns display off but is stiil on.
The display can be blacked out on the 9857r. To toggle between display on and display off hold the function button until it beeps.
SOURCE: No display on biolite screen
Yep I have a solution what has happened which is common with hard drives is your file table has forgotten where the image / video files for the menu are located. I had to dissassemble my hard drive and have the data recovered. Good thing the hard drive was still working. With it apart I've now backed up the information on the drive so if I have to replace it I know how to do it now.
SOURCE: Troubleshooting on Adjusting Treble/Bass
Look in your owners manual and make sure you are turning the right knobs or pushing the right buttons once you have the adjustment screen for the bass/treble showing. It could be that they use different knobs/buttons than the volume control. If you are using the right controls, then you have a problem that only a shop can fix. You might reset by taking away all the power (acc and bu) for a couple minutes and then reconnect, but if that doesn't help then it time to go to the shop.
