2wire Wireless-G 802.11g ADSL Gateway Logo
A
Anonymous Posted on Aug 14, 2014
Login optus Log in with my email and password to the new modem
Anonymous232
Level 3:
Genius:
  • 2wire Master 1,552 Answers
  • Posted on May 07, 2015
Anonymous232
2wire Master
Level 3:
Genius:
Answers
1552
Questions
Helped
270335
Points
2945
The ID/password that you should use are printed on the bottom of the router -- using your E-mail ID/password will not work.
I have 3 computers and on my 2 older ones when I want to log in to my Optus Webmail they have somehow configured themselves to bring up my password (albeit it in ****** form) so that (cont. below)
Usually, your web browser will offer to remember the password or Optus Webmail itself sign-in/login page will have a small checkbox which tells Webmail to remember the password.
The main risk here is that if your laptop is lost or stolen then anyone can read your email and change the password to something else; so, consider that before having the browser or Webmail store the password.
2answers
I have a problem with my Facebook I can login for the pass 2weeks
Point your web browser at http://www.facebook.com
If another account comes up, log out of it by clicking the down-pointing triangle in the upper-right then clicking "Log Out."
If you then still can't log in to your account, click the "Forgot your password?" link located just below the password box on the login page.
Can not remember my facbook password i have a new email address that i would like to have this seant to
You can request a password reset by clicking the "Forgot your password?" link located near the "Login" button on the log in page. We will then send you an email with a link to reset your password.
If you no longer have access to the email address you use to log in to your account, or you forgot what this email is, please refer to the "My login email address is invalid or expired" section of this page.
Hope this helps.
1helpful
3answers
I have an optus netgear router model DG834G v5 and trying to set it to work with Telstra Bigpond, but don't know how to.
To bypass the Optus login page type in the address bar 10.1.1.1/CA_HiddenPage.htm
It will ask to disable the Optus login, accept, then close the page, open a new page and type in the address bar 10.1.1.1
And you will be at the router login
Username: admin password: password
Best of luck
Anthony
1helpful
I lost my install disc, can I download one for free?
YES. here is a link for you to follow but please read the article here before you download anything as which operating system you are using makes a huge difference to which driver to install. Also, if you are using OPTUSNET as your service provider, you can download the optus driver from www.optusnet.com.au. If you install the siemens driver, it will erase the optus settings in the modem and in the configuration file which is hidden within Windows. If this happens, you will have to reconfigure ALL the settings including your login and password.
1helpful
No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
  • If you are connecting via USB you will need to run the self-installation CD to install the USB driver before you connect your modem. The Siemens SpeedStream 4200 ADSL modem supplied by Optus has been customised for the Optus DSL Broadband service. Only the USB driver supplied on the self-installation CD will work with the Optus service. If you do not have the self-installation CD, you can download the latest drivers from the Siemens website.
  • If you are connecting via Ethernet it is possible to manually configure your modem without the self-installation CD. Only a web browser is required.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
  • PC settings - Configure your computer's Ethernet network interface.
  • Configure Your Modem - Set the password in your modem's configuration pages.
top
PC Settings Step by step instructions are provided for each of the supported Windows operating systems:
  • Windows 98/Me
  • Windows 2000
  • Windows XP
  • Windows Vista
top
Configure Your Modem To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
  • Enter http://10.1.1.1 (Default IP address of the Optus Supplied Siemens SpeedStream 4200) to access the modem Configuration software. You may wish to add this page to your Favorites for easy access later.
  • The following modem System Summary screen will appear.
ss4200_home_disconnected.gif Step 2 of 5
  • Click on the word Setup in the green menu of options on the left side of the web page. An expanded set of options will be displayed.
  • Click PPP in the list of options that appeared below the word Setup.
  • The ISP Password page will appear:
  • Replace the default username ([email protected]) with the username provided for you by Optus DSL Broadband.
  • Replace the default password with the password provided by Optus DSL Broadband in the Password field.
  • Note: You will find your Optus DSL Broadband username and password on the letter you received with your self-installation kit.
  • Save these details by clicking the Save Settings button.
Step 3 of 5
  • The next screen will ask you to disconnect and reconnect to the Optus DSL Broadband service.
  • Click the link to return to the System Summary page.
  • Click the Disconnect button to disconnect the modem from the Optus DSL Broadband service. The text on the button will change to Connect.
  • Click Connect to reconnect the modem to the Optus DSL Broadband service.
Step 4 of 5
  • Click the word Mode in the green menu of options on the left side of the web page.
  • Confirm that Optus Bridge is the selected operation mode.
  • If Optus Bridge is not selected click the radio button next to Optus Bridge to select it.
  • Click the Apply button.
  • Click the Reboot button to restart the modem using your saved settings.
  • After about a minute the modem will return to an operational state and connect to the Optus DSL Broadband service.
ss4200_reboot_3.gif Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
2helpful
Lost password
hi there i need to no if its a sim password or phone pass word if its a sim password enter any number 3 times and it will say , puk blocked then ring your provider (optus virgin ect tell them your details and mobile number and they will give you your puk number enter that and it will say enter new password and repeat ,,,,if it is a phone lock u can take it to a phone dealer they copy the imei number and try to reset your passsword
Jul 01, 2008 • Cell Phones
Forgotten password on login page
Try looking on the modem itself, sometimes they have their default username and password written on them. Try combinations of "user" or "admin". eg username: "admin" password "admin"
if these don't work and you don't know why you can't log into your modem, try resetting your modem using the reset button on it (or holding the power button for 10-20sec) and then try the above suggestion again.
If you still can't login, write back with your modem make and model number.
Top 2wire Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
