Start with 77 lbs. if your systems target is 3200 ppm. Then test after 24 hours.
Math : 1 pound salt per 40 gallons water for 3200 ppm when starting from zero ppm. 22' x 22' x 4.33 x 5.9 =3091.19 gallons
3091.19 / 40= 77.28
I answer this making the assumption you have a round pool and your salt system calls for 3200 ppm and you are using a quality pool grade salt. It is worth the money to use pool salt.
Here is the formula if you have another shape pool. If you have pre chlorinated water you may have a salt level higher than zero so test before you start. It is better to under salt and add more later if you need.
Gallons
(pool size in feet)
Rectangular
Length x Width x Average Depth x 7.5
Round
Diameter x Diameter x Average Depth x 5.9
Oval
Length x Width x Average Depth x 6.7
The equipment should specify the parts per million of salt required, just google your make and model for information, then take the volume of water(22 x 52 x average depth) and multiply by the required salt concentration. then divide by the bag weight to get the number of bags required. Get some spare bags, but start with a few less than calculated, this enables fine tuning as you test the water a few times
SOURCE: My intex saltwater system pump is beeping
Yes, and be sure to keep up with your pH as it will want to rise slowly over time when using a salt water chlorine generator.
SOURCE: how much salt do i put in my pool. its 18 feet by
for the 18x48, you will add 135 pound (60 kgs) to start. When the Low Salt light comes on you add 35 pounds (15kgs)
SOURCE: My salt water gets green then, i shocked it and
Your last sentence says it all
So many peolpe are led to believe that using a salt system takes away the need of other chemicals
This couldn't be further from the truth A salt system just makes it so that you do not have to physicaly ad liquid chlorine or float tablets
First of all lets get a little educated in pool maintainence 101 and then I will address your problem ( First problem was buying an Intex product ) but I will cover that too
You can not just blindly ad salt to the system
you need to get a salt test kit that reads in #'s not color
You need to get the water to as close to 3000ppm as possible
Any lower than 2700ppm and you can trigger low salt alarm, not to mention not generating enough chlorine
Any higher than 3500 and you can go cloudy, trigger high salt alarm and you could go cloudy
Now for the intex curse
not a single pump/filter is sufficient with the pools they come with
They are to small
A pool needs to be turned over at least 3-4 times in a cycle 24 hours
I do not know your gl or pump size so I will use generic #'s
If you have a 5000gl pool and a 1500gl pump thats 10 1/2 hours of filtering at the minimum
Use your #'s and figure out what you need to be doing
You want to start by getting your salt right this is crucial What it says in the manuals is just a starting point the fine tuning is up to you
Lets now side track and I will tell you how to cure your problem.
This is time consuming but will give you the best results
Blast out your paper cartridge with the water hose now ad 1 gallon ofliquid chlorine
Filter only for 24 hours now brush your pool with a pool brush not the bristles under your vaccum not enough of them to do any good
now clean the filter again and run for a few hours until you see things settle down
Vaccum and clean the filter and start over again
Check your chlorine if it is normal or low ad another 1/2 if it is super high then leave the chlorine step out
Once you are clear again or close to it Ad a non foaming algecide and also ad chlorine stabilizer this is a chemical that you put in a nylon sock and float it behind the ladder this will help hold the chlorine
Once your chlorine level is at the point you can swimm again you should get your best swimmer to get in with a tooth brush and clean the over flaps in the seems that are on the bottom and where the sides connect to the floor
This should do it
lets look at one more thing
Chlorine generation
There may be night that you need to run it 12 hours for chlorine and other nights 5 or so
It all depends on many factors
sun,heat,number of swimmers, sun tan oil and so on
The biggest thing you can do wrong is to not use the pool If it is not being used every day you should brush sides and floor every 3 days or so. The pump is not strong enough to circulate the water properly
One more thing that I do and I have not changed my filters in this being my 3rd season
I have 2 one is always drying
Start with a dry filter and have the other clean and drying
Change them every couple of days.
Never try to use a wet filter it does not work like a dry one
Dont ask why it is just one of those mysteries
Also periodicaly take the hose off the front of the motor your inlet hose this can build up hair and debris that gets in from skimming
Good Luck
Don't forget to rate this
Testimonial: "I sure am glad that I finally got real answers to my question. Thanks!"
SOURCE: Hi, I have let my
You need to get liquid chlorine and add about 2 liters and let your pool filter run for a couple of days and in the mean time clean your filter twice daily. If the pool at this stage is still a little green add more chlorine and broom the bottom to stir it up. After this as once your pool is back to almost normal, clean the the filter again and add clarifya. To keep your pool in good condion over summer buy 2 pool floaters, put 2 chlorine tablets in one and blue block pool sparkle in the other and each week add 1 liter of chlorine. Hope this helps you as i have the same pool and i do this and don't have any problems. You can also add salt to your pool if you like but dissolve it in water before you add it to the pool.
