Intel Dot Station (INTC300AIO) PC Desktop Logo
A
Anonymous Posted on Jul 13, 2014
Why won't my HP laptop let me type anything? - Intel Dot Station (INTC300AIO) PC Desktop
sureshd2008
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 83 Answers
  • Posted on Jul 14, 2014
sureshd2008
Expert
Level 2:
Cheetah:
Answers
83
Questions
Helped
29186
Points
219
Whichf HP laptop? Is your PC hung up? What version of Windows?
Usually you can do a CTRL-ALT-DELETE and this brings up the Task manager. If your keyboard has a proper driver loaded, it will show you the Task manager screen. Select - start task manager. then look at the list of Processes. There should be atleast 9 processes running. Sometimes a virus in your system can lock your keyboard just to irritate you.
Can not acess my Netflix account freetrail
Make sure you typed your Netflix id is correct.
Make sure you typed in correct case. Capital/Small caps
If these are accurate and you are unable access the account , contact Netflix by email.
That's the best option.
Laptop inspiron 15. after typing password. won't open.
try reinstalling operating system from back up cd. If that do not resolve the problem, contact a good pc hardware engineer or chiplevel service engineer. They can solve the issue. Hope it helps
My LGL55C powers up and goes to the b lue screen n won't boot up or do anything won't turn off .
Dear Chris,
Seems like a bad RAM. Simply change your RAM and then give your laptop a go and it shall be all fine and smooth sailing on wards. You can test it by simply borrowing a RAM from your friend for a while. But do make sure that RAMS are of same type.
My HP Pavilion dv2000 won't type the correct characters
Sounds like the hardware is brain damaged in the keyboard, I suggest getting a new on off e-bay and replace it.
Half my keyboard won't work cq50
The keyboard in the laptop must be replaced, go to www.ebay.com Type: make and model, refine search to keyboard.
Pls,i have a nc6000 Hp laptop of 40GB Hard disk, 1500MHz processor and a 256MB RAM which i added 512MB RAM to upgrade to 768MB RAM. It started to freeze/hang and prompting the mouse cursor to...
from the off position, turn on, continuously hit the F8 key to force the startup menu, select last known good configuration and reboot. If this does not work, do the F8 thing again, and select safe mode. If you cannot reboot, you will have to do a clean reinstal using your factory recovery CD. If you can get into safe mode, immediately start saving your files to whatever media device you can.
go to start/run and type cmd and hit enter - type in chkntfs /c e and hit enter, reboot. This will start and system checking procedure on bootup. Again, if this does not fix things you will have to boot from your recovery CD.
Hp won't turn on. When hit power, hear fan, HD run, few secs it turn off, try to to anything from hp list what to to, won' work.
Motherboard is defective & needs to be replaced with a new one.
You can find a replacement motherboard by searching on e-bay.com with the motherboard's model number. This could be found under the RAM.
Power on password!
YOU should type your password then press enter or attach a usb keyboard then type
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
