2014 Volkswagen GTI Logo
D
Derain Posted on Jul 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vw golf VII radio wiring diagram
I need to connect an external audio amplifier and require the factory radio wiring diagram to interface the amplifier to. where can I find the wiring diagram?
Neil
Level 2:
Sergeant:
  • Volkswagen Expert 451 Answers
  • Posted on Jul 20, 2014
Neil
Volkswagen Expert
Level 2:
Sergeant:
Answers
451
Questions
Helped
141590
Points
730
Hi. There should be a multi plug diagram on a sticker on the radio itself.
5 Related Answers
Anonymous
  • Posted on Apr 11, 2010
SOURCE: vw golf .... alpha...... safe 2
"2 safe" means that your radio was in safe mode, and then the code was improperly entered 2 times. you either need to disconnect your battery and leave it for up to 4 hours (i've been told), or leave your key in the ignition for around an hour.
once it comes out of "2 safe" mode, then it will just say SAFE and give you the numbers 1-0-0-0. You just need to enter the 4 digit code (using your pre-set numbers 1-2-3-4 to change the numbers), then hold the seek > button and your radio should come on.
If you don't have the code, call VW. they'll find your code for free. they did for me. if not they'll charge like $50 or something.
Anonymous
  • 193 Answers
  • Posted on Nov 22, 2008
SOURCE: VW Polo Dash Instrument's
buy a repair manuel from a parts store. Check to see that it has the wiring diagram in the manuel.
CarMan
Douglas Felsenthal
  • 53 Answers
  • Posted on Jun 05, 2009
SOURCE: wiring diagram for fuse board
This info is in the Shop manual - VW or Helms out of Detroit. You could also search the web forums.
Regards
Doug
Anonymous
  • 30 Answers
  • Posted on Aug 01, 2009
SOURCE: Need an engine diagram of VW Golf 1996
here is the diagram.hope it helps.
Chad Baldwin
  • 88 Answers
  • Posted on Apr 06, 2010
SOURCE: i need a wiring diagram for a 96 vw golf gti vr6
http://www.the12volt.com/installbay/alarmdetail/2180.html
WIRING DIAGRAM REQUIRED FOR MY GOLF 1600I YEAR 2006
VW does not share their technical manuals online.
Looking for a wire diagram to hook up a aftermarket sterio from factory on a 2001 chev malibu
In this car you will need an stereo adapter. Some functions of the cars warning system are in the radio. You use this adapter to replace the factory radio. The adapter facilitates replacement of a factory radio while retaining all factory safety warning chimes and audible turn signal indicators. These adapters are compatible with amplified and non-amplified audio systems. Will retain all safety warning chimes. See this web site for more info. Autosound Central. With the right adapter you do not need a wiring diagram. It will be plug and play.
Radio diagram for 2004 nissan titan
DIRECTWIRE™ WIRING INFORMATION - NISSAN / TITAN / 2004 / Audio
Radio 12v yellow + radio harness
Radio Ground (chassis)
Radio Ignition purple + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/white + radio harness or amplifier
Notes: If equipped, the BOSE amplifier is to the right of the steering column, behind the BCM.
Power Antenna N/A
LF Speaker +/- blue/white - blue/red +,- radio harness or amplifier
RF Speaker +/- white/black - blue/black +,- radio harness or amplifier
LR Speaker +/- lt. blue - black/yellow +,- radio harness or amplifier
RR Speaker +/- orange/blue - red/blue +,- radio harness or amplifier
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on the SE and LE models. Optional on the Crew Cab XE models.
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Hope helps (remember to rate this nswer)
1helpful
Im changing factory radio to jvc and cut wires which ones are power source
here is a wiring color break down.
1987 Lincoln Mark VII Car Radio Wire Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Pink/Blue
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Blue/Orange
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
please rate my help.
What wires do i connect for my cd player? What colors connect?
here are the factory wire colors and what they do.
1999 Ford Escort
Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Green
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: White/Orange
Car Stereo Amplifier Location: Under the driver seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
