Generator alarm underspeed
When you get the under speed alarm is the generator under load? Try manually starting the generator with no load and let it run for a while, if no alarm, then put it under your home load and measure current draw (maybe have an electrician check it) if the amp draw and in rush caused by compressors, pumps motors etc are within the generator rating, check your fuel pressure, on average 8-11 WC Nat gas. Pressure may test well under no load but drop starving the engine of fuel unde rload. Underspeed is just that engine cannot make RPM/Frequency
