Check this generic procedure: 1. Follow the harness side of your seatbelt (this is the side you pull across your shoulder and lap to connect to the anchor side) to the points where it connects to the car frame. 2. Using a flat head and Phillips screwdriver, unscrew and pry off any plastic housing that is covering the bolt connections. Select a socket that will fit the bolt and attach the wrench to the bolt. 3. Feel underneath the car for the other end of the seatbelt bolt. Fit a box wrench to the nut and hold it still while unscrewing the bolt with the socket wrench inside the car. 4. Unbolt the shoulder attachment of the harness with a socket wrench. Remove the harness side seatbelt from your Toyota Corolla. 5. Install the new harness side seatbelt by reversing the removal steps, however, make sure to use the new hardware provided with your replacement belt. 6. Feel down at the bottom of the anchor side of your old seatbelt. There will be one bolt and nut attaching it to the bottom of the car. Remove the bolt using a socket and box wrench. 7. Install the replacement anchor side. Before you tighten the bolt, connect the seatbelt and make sure that you have the anchor side facing the correct direction to receive the harness. When it is right, tighten the bolt.
Hope this helps; also keep in mind that your feedback
is important and
I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
You may be missing a piece. Take a look at the Prima Pappa manual from the Perego website. You can buy a new high chair harness if you are missing pieces.
There should be a pedal on the bottom support that has a red tab. Press down on that with your foot while pulling up on the tabs on the side. This will expand the unit. This is for the Prima Pappa Best model. There are other Prima Pappa models though.
