Peg Perego Primo Viaggio Verde Infant Car Seat Logo
Question about Peg Perego Primo Viaggio Verde Infant Car Seat
Styrofoam insert for Peg Perego Infant Car seat
I have a Peg Perego Infant Car seat. It is in great condition, except for the styrofoam insert. Is there a place where I can purchase just a new styrofoam insert?
Posted by chloe923 on
Anonymous
    New Friend:
Hi, I figured I would post the outcome since I was searching for resolutions. I called Peg Perego. The piece that is cracked on my Peg Perego Primo Viaggio SIP Infant Car Seat is the top of the center section of the headrest. The representative said it can be replaced with a new headrest piece for $32.99 (including shipping). The new piece does not have stryofoam though. It's just a heavier material (almost pillow-like). The representative that I spoke to, however, said that if the styrofoam was a clean break (meaning not in a whole bunch of pieces) it's still safe to keep it together under the cover and use the car seat as normal. Apparently, that's not what's really protecting the baby anyway. To be honest, I don't even think that I broke the styrofoam while taking the cover off, I think it was broken beforehand probably by just use and the weight of the baby. I will get some styrofoam glue and duct tape and just secure it, and put my sparkly clean cover back over top of it. I think it's fine for use. Thanks and good luck to others with this issue out there!
Posted on Sep 29, 2010
Anonymous
    New Friend:
I'm looking for it as well!
Posted on May 12, 2010
  • Anonymous Sep 25, 2010
    I too cracked the styrofoam insert while taking off the cover for washing. I cannot seem to find any information on replacing the broken piece either. Luckily, the piece that is broken just cracked in a clean line. I think I may be able to duct tape it together and put the cover back over it and it will stay together. However, I would be interested in actually replacing the piece for peace of mind, so any information is greatly appreciated. Thanks!
I need diagram for the infant car seat. Trying to get straps back after cleaning seat cover
You may download your Peg Perego Primo Viaggio manual from this LINK.
I hope this works for you. Thanks for using Fixya!
Mongkey
"Understanding explains better..."
3helpful
Need a new chest clip - are they available for purchase?
Call Peg Perego @ 800-671-1701. They sent me a new one for free.
I bought the Peg Perego Venesia Stroller and Primo Viaggio infant car seat used. I do not know how to run the straps through the infant carrier or how to completely attach the carrier to the car seat...
hi I'm sure this is just the newer model the uno looks the same as the venezia
http://global.pegperego.com/babyproducts-catalog/2010/Uno
instructions available at this website
2answers
Peg perego car seat on a stroller?? how??
Peg Perego car seat is only compatible with peg perego strollers.
It is not clear from your very laconic question what you really need.
If you need to install a peg perego car seat on a peg perego stroller, then just look into the manual, OR, if you don't have one, search for it online.
In case you need to install a peg perego car seat onto any other stroller, I doubt a lot, it is possbile...
I am in an opposite situation.
I have got a peg perego stroller, but another type of the infant seat. After long searched online, we understood that once you buy a stroller, you almost always have to buy a car seat from the same company, or you won't be able to use it as a travel system (which is exactly how we are going to deal with the situation)
I need to replace the styrofoam form for my primo viaggio seat. I believe the part is mmsp0008
Hi, I figured I would post the outcome since I was searching for resolutions last night. I called Peg Perego. The piece that is cracked on mine (the top of the center section of the headrest) can be replaced with a new headrest piece for $32.99 (including shipping). The new piece does not have stryofoam though. It's just a heavier material (almost pillow-like). The representative that I spoke to, however, said that if the styrofoam was a clean break (meaning not in a whole bunch of pieces) it's still safe to keep it together under the cover and use the car seat as normal. Apparently, that's not what's really protecting the baby anyway. To be honest, I don't even think that I broke the styrofoam while taking the cover off, I think it was broken beforehand probably by just use and the weight of the baby. I will get some styrofoam glue and duct tape and just secure it and put my sparkly clean cover back over top of it. I think it's fine for use. Thanks and good luck to others with this issue out there!
1helpful
Car seat without base
You cannot use a Peg Perego Infant Seat without the base. There is no belt path on the seat itself.
I would lik to know how to remove the canopy of my infant car seat to be able to replace it with another one.
I copied these picutres from the manual. They show how to remvoe the sun shade for the 2007 and 2008 Peg Perego Viaggio.
Peg perego venezia stroller with infant car seat
you should be able to turn them how you want then lower the lver the way you want them to lock hop it helps
1helpful
Car seat instructions
Here is the link to the online manual for the 2007 Perego Car Seats. give it a few seconds to load. It will be a white page while it loads.
http://www.pegperego.com/pegcatalogue/juvenile/downloads/PrimoViaggioSIP-US_FIUS0603I61.pdf
Follow the remove instructions in reverse. It is difficult to describe, but the pictures are very helpful.
Good Luck! from Moms Just Know
Top Peg Perego Baby Gear Experts
Marvin
Marvin
Tom Chichester
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
