SOURCE: Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
SOURCE: SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
SOURCE: Will not power up, stand by light flashes 9 times, then restarts flashing but never powers up
Well if you know eletronics then yes you could fix it yourself otherwise leave it to the experts you going to need a new power supply unti for this TV. These are not cheap as there aftermarket you may want to try to find a dealer on the internet for this part. Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Flashing light
The LED used in most tv are dual color led,some have two lead, some have three. try to find the same size and replace it.
If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
