SOURCE: The instructions for the Homedics SC-540 (SC540)
I had the same problem. However, you can request its manual to customer service, [email protected]. I received the manual in a few days via email.
SOURCE: Scale wont work
Sounds like a warranty issue. I would try to return to place of purchase if not here is web address on manufactures site with instructions on warranty.
http://www.homedics.com/products/warranty-returns
SOURCE: I just put in a new battery in my Homedics
I would contact HoMedics here is contact form
http://www.homedics.com/products/contacts/
SOURCE: i changed the batter in
Open it again and make sure the battery is in the correct angle..... I have made this mistake from time to time
SOURCE: The Homedics SC 380 scale said low battery. After
The same happened with me, but here is what I did and it worked. I took the new battery out and set the setting on the bottom of the scale to Stone, put the battery back in. Now when I put the battery back in I made sure the plus on the battery was the last part to go in, it faced the part inside the casing that needs to be pushed back when you take out the battery. Once it was in I put the setting back to LBs and it worked. Don't know how but I was just as frustrated and it worked.
