Run Fixup command line tool (fixup -f)
Load fixup -i mail\file.nsf
Fixup command line tool checks all documents in the database.
Run Compact command line tool (compact -i -c -d -K)
Load compact -c -i mail\file.nsf
With Kernel for Lotus Notes to Outlook Converter software Lotus Notes to Outlook migration is now not a big task. It is a fast, accurate, and easy to use NSF to PST converter tool. It will support all Lotus Notes and Outlook version. Apart from this it will also help user to migrate Domino Server mailbox accounts to exchange server mailbox and also allow user to save their data in TXT, RTF and HTML file format. To more information about software one can go to http://www.nsfpst.org
Click Start, point to All Programs, point to Lotus Applications, and then click Lotus Notes. Because this is the first time you have run Lotus Notes, the Lotus Notes Client Configuration Wizard starts. Click Next.
On the Welcome page, click Next.
When
prompted, type in the name you set up for the user ID for Exchange
Connector for Lotus Notes and enter the name of the user's home/mail
Domino server. Select I want to connect to a Domino server. Click Next.
On the How Do You Want to Connect to a Domino Server page, select Set up a connection to a local area network (LAN), and then click Next.
On the Domino Server Network Information page, in the Domino server name
text box, type the name of the Lotus Domino server that will act as a
bridgehead between Exchange Server 2003 and Lotus Domino. In the Please provide specific network information to help locate this server dialog box, select TCP/IP. In the Server address field, type the hostname or IP address for the Domino server listed above, and then click Next. This server should be the one that you configured earlier.
When asked if you want the User ID file copied to your data directory, click Yes.
Type in the password for the user ID file.
If prompted to set up Instant Messaging, clear the Setup instant messaging check box, and then click Next.
On the Additional Services page, click Next.
You will receive a message that indicates that Notes setup is complete. Click OK.
Verify
that the selected location is set to Office (should be displayed in the
lower-right corner of the Notes client). If not, select the name
displayed there and then choose the Office location.
It's probably looking for names.nsf on your pc. Try c:\lotus\notes\data\names.nsf or search for it. The fact that it can sync email without error tells me that it's NOT looking for your id file (name.id). There's a slight chance that it's looking for your notes.ini file (c:\lotus\notes\notes.ini) on your pc.
