It sounds like you are using the wrong mic for the radio or the mic has been wired incorrectly or the mic has become faulty or the radio has become faulty. Unplug the mic and see if the radio receives and works correctly. You should be using a Yaesu model MH-36b or a MH-42B microphone.
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ps4
IIC bus clock and/or data lines low at power on
06 6 blinks denotes this. The main digital board should be troubleshooted. If you wish to know more about the blinking codes to Panasonic TVs, check this link.
It could be small transistors--in the back where the light and transmit hook up. One small transistor will shut down transmit & possibly receive. Get it serviced at a radio repair shop. if you know how do it yourself. Change all small transistors to 2sc3904 or 2sc 3906 at "Radio Shack."
Hi, with thse symptoms, the most likely cause is a failed connection or dimmer switch, but the headlight switch is also a possibility. Your dimmer switch is integrated into the control wand. I cannot seem to find the instructions for removing the wand, but I think you remove the clamshell from the column and then unscrew the wand assembly from the column. You can test the switch by leaving the cable attached and back-probing the connector with a 12 volt test light or voltmeter. The light green wire should be hot when the headlights are turned on. Leave it on and then probe the red and purple wires. The purple wire should be hot when the switch is on low beam. The red wire should be hot when the switch is on high beams or flash position. If there is no power on the green wire, the headlight switch has failed or the green wire is disconnected or loose. Please let me know if you have any questions, and thanks for using FixYa.
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
If the back was off the board on the left is your Ysus board. It will have a cable plugged into the right side of the board from the signal board. Unplug the the Ysus board. If it stays on without a picture change both Y and Z sustain boards. If this helps let me know.
Your concern is no transmit and no red transmit led -
If there is no receive likewise, then probably problem in the PLL/VCO section or 9V voltage regulator TR23 (2SC1096) or Zener diode D22 (9.1V).
If the receive is normal, then possibly any of two (2) faults: 1. microphone/PTT switch and/or the mic cable specifically the wire connected to pin# 3 of the connector; or 2. +8V switching transistor TR21 (2SA733P).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
