Question about Cobra 29 LTD CB Radio
Red RX/TX and red ANT light on my CB
Just bought brand new Cobra 29 ltd Black Chrome new antenna new mount and cable. Everything new and getting red lights on both Ant and RX/TX. Tried the other antenna I had Wilson 2000 same thing. Tried using the cable already installed on truck and only RX/TX is red my guess is it's the cable that need to be replaced just wanted to ask someone else. But I still have the red RX/TX to deal with any help????
JOHN BABA
    Genius:
  • 1,274 Answers
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
Posted on Mar 12, 2010
Testimonial: "Thx the rx/tx light is supposed to turn red I found out. Still trying to get the antenna prob fixed though."
  • JOHN BABA Mar 12, 2010
    Well, there should be a small allen screw at the base of the steel rod,i think its about one eight or three sixteen,loosen it and slide the whip up or down to adjust it, you may have to cut it one quarter at a time....then retighten......hope this helps....
I have had a Cobre 29 LTD Classic, a 29 NW LTD Classic and now a 29 LTD Chrome.It seems that the first two died because of possible bad antenna connections. I was able to calibrate the radios and adjust...
I see two possible problems. First, with a magnetic antenna it is difficult to get the proper ground for the antenna. Make sure the magnetic base is clean as well as where you place it. Second, try running your power lead DIRECTLY to the battery and not using the cigarette lighter. Hope it helps.
Tom
Feb 27, 2013 | Cobra 29 LTD CB Radio
HELLO STAN FIRST HAS THE RADIO BEEN PEAKED AND TUNED? SECOND IS THE INTERIOR LIGHT IN YOUR PICK UP RIGHT BELOW YOUR ANTENNA,IF SO YOU HAVE A PROBLEM BUT EASY FIX THE WIRING GOING TO THE LIGHT ACTS LIKE AN EXTRA ANTENNA CAUSING YOUR ANTENNA TO RESONATE TO YOUR RADIO CAUSING THE A W I LIGHT TO COME ON MOVE YOU ANTENNA BACK A LITTLE FUTHER AND SHOULD BE GOODif you want to get a bettter antenna get a willson 500 mag mount far better
Red lights come on tx n rx and antenna come on when I key up the cb radio and the swr meter doesn't move
if a mod has been done to the cobra 29 (all 29,s)the light will come on just find vr6 audio the radio as it comes on adjust vr6 untill it goes away,,,,always trust your watt meter(s.w.r scale)over the flashing light its really easy to do it beats paying a shop $10-$15
Jan 13, 2013 | Cobra 29 LTD CB Radio
Just bought a cobra ltd crome ive mounted every thing how to i clibrate it with my attenna? when i key up both rx/tx and ant lights up red?????
This is a common misunderstanding when it comes to communications equipment. You don't tune the antenna to the radio, but rather you tune the antenna to the vehicle. the vehicle is the ground plane for your antenna system.
With that said You will need an SWR Meter between your antenna and Radio. follow the instructions for your meter for calibrating the meter and follow the instructions for your antenna for adjusting the length.
Jul 14, 2011 | Cobra 29 LTD CB Radio
When i key in both green lights turn red. is this normal ?
One of the lights is marked RX/TX. This light normally turns red when you press the mike key. The other light indicates a bad SWR if internal circuits are properly aligned. If someone has turned the pot which sets the level at which the light comes on, it may come on when you press the mike key. Check your SWR with an external meter to see if you have problems in the antenna system. The way I set this light in my shop is to put a 150 ohm resistor on the antenna connector and set the control so that the ANT light just comes on.
Jun 15, 2011 | Cobra 29 LTD CB Radio
My rx/tx light is green untill i push on the mike. then the light turns red. and the antenna led theres nothing. whats could be the cause and the fix...and the swr metter goes into the red all the way to...
Its working alright then...what the antenna light is for in case the SWR is too high. If it does not come on---Then it means your antenna works good.
May 16, 2011 | Cobra 29 LTD CB Radio
CB Radio has red light on Rx and red light on antenna, how do I fix that problem? I don't remember how to adjust my CB right, no longer have the manual for it. Its a Cobra 29 "Dale EarnHart Jr. "...
The red light on rx is fine, it's supposed to change from green to red. The red light on your antenna means you have a swr issue, something in your antenna system is not right. You need to go to a reputable CB shop and have them check your swr.
Aug 09, 2010 | Cobra 29 LTD CB Radio
Problem while matching CB
You need to understand how to tune an antenna and how the antenna works.
read this article
How to tune your antenna
and here is a list of causes for high SWR
Oct 28, 2009 | Cobra 29 LTD CB Radio
When i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Oct 02, 2009 | Cobra 29 LTD CB Radio
The ant light and the other light light up red when i key the kic
the tx/rx liight is green when your radio is recieving signals and turns red when you are sending signals. the ANT light is red when your SWR is too high (over 3)
1. turn the knob labeled swr cal all the way counter clockwise
2. set the rf swr cal switch to the CAL position
3 key up the mic and hold it while you rotate the swr cal knob until the needle reaches the swr cal postition
4. set the swr cal rf switch to the swr position
5. key up the mic while on chanel one (record the the number)
6. switch to chanel 40 key up the mic (record the number)
if the number on chanel one is lower than the number on chanel 40 then your antenna is too long.
Sep 14, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
2,224 people viewed this question
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
