SOURCE: I HAVE A SAMSUNG NP-N130 AND THE SCREEN HAS IS
yes call samsung if you have warranty they will come and install a new screen
SOURCE: pls let me know how to rotate back original screen
Right click on an empty part of the desktop away from the icons and scroll down to you see either ATI or Nvidia control panel, if you do simply choose that and in the left hand pane you will see "screen orientation", choose "Landscape" or "0" degrees. Click apply and ok.
If there is no video control panel then scroll to the bottom and click properties, go to dispaly settings and then to advanced settings. Look for screen orientation and choose "landscape" or "0" degrees.
SOURCE: Screen coming on, but only displaying grey lines.
You might have blown it, you'll need to talk to a repairer to see if it can be repaired at a reasonable cost.
But what you can also do, is connect it to an external monitor. I've just had a look at the specifications on the web, and there appears to be a VGA port (blue trapezoid connector with about 21 pins/holes).
Using the Fn keys, you should be able to switch between internal and external monitors.
As for data recovery, you should be able to remove the HDD, buy an external caddy, put the HDD into the external caddy and use it as a backup drive and retain/access the files you need.
or, if you can use an external monitor, copy them to anywhere you like. For precious photos and music files, I would suggest writing to DVD.
Testimonial: "Thank you very much; all those solutions are very helpful indeed!"
SOURCE: Samsung NP-NC10 Screen all lines and 'jumpy'
got the same problem before with my compaq laptop. i replaced the screen with a new one.
SOURCE: hy i want to
There was no Vista driver released for you netbook, and if you have 7 I don't recomment you go back to vista, but if for some reason it is essential to you tis is how you can do it.
Install Vista, download your netbook drivers for XP here on samsung website.
Then follow this tutorial to install them under Vista.
Hope this helps.
