Casio FX-300MS Calculator Logo
A
Anonymous Posted on May 04, 2014
What is the formula to calculate the volume of a 1/4 in thick equilateral triangle hamburger?
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Aug 27, 2014
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4675756
Points
21596
Calculate the area of the base (you need the measure of the side) in sq. inches and multiply by the height.
2answers
Finding area of a Triangle in the Coordinate Plane
The area of a triangle is 1/2 times base times height. A sketch of the triangle in the coordinate plane will determine how easy or hard this will be to be. From the sketch, you will see that this is a right-angled triangle with B being the right-angle. This makes it easier because we can easily determine the base and the height to use in the formula.
We can chose AB or BC to be the base, while the other will be the height. If we choose the base of AB, its length is 4, the 6 - 2. The height is 9-(-4) or 13.
We can now put the length and height into the formula to calculate the area of the triangle.
Good luck.
Paul
Calculate gallons of a tank
I assume the length of a side is 16 in, and the height of the prism is 23 inches.
Volume of a prism is V_prism=(Area of base)*(height of prism)
Area of base is made up of the area of the 6 equilateral triangles with sides =16 inches. The height of such triangles is given by 8*SQRT(3).
Use the Pythagorean theorem or the trigonometric ratios to find the height of each of the 6 traingles.
Area of base =6*16*(8*SQRT(3))/2 sq in
Volume =6*8*8*23*SQRT(3) cubic inches
Calculate the value in cubic inches and convert to gallons: I leave that task to you.
Volume of triangular pyramid
Here is to get you started. To increase the size of the image do a CTRL Plus (+) in your browser.
You need to calculate the slant height of the pyramid for the formula of the lateral area. You should find a value of (1/2)*SQRT(203) or about 7.1239 cm
You need to calculate the altitude (height) of the pyramid from the apex (summit) to the center of the base triangle (center of inscribed circle, barycenter, orthocenter). The hypotenuse of such triangle is the slant height. One leg is the altitude (to be found), the measure of the second leg is (1/3) the altitude of the equilateral triangle that forms the base. You should find (1/3) m MH= (1/3)* (11/2)*SQRT(3)
1. Calculate the area of the base (use a formula for the equilateral triangle or the general formula for a triangle: you have its height MH ).
2. Lateral area = 3 times the area of triangle Triangle ECD (in yellow above).
3. Total area = area of base + lateral area.
4. Volume= (1/3)(Area of base)* (height of pyramid)
If you can see the details on the screen capture below, fine, Press CTRL + in your browser to increase the size.
2answers
How can you classify a triangle according to it angle? is there a formula for it
Well, there is classification by sides, equilateral with 3 equal sides, Isosceles with two equal sides, and scalene with no equal sides, but you talk about angles, but I wanted to point out equilaterals have 3 equal angles, isoceles have 2 equal angles and scalene have no equal angles.
So, now we talk about angles: a Right trianlge has one angle that is 90 degrees, an Obtuse triangle has one angle greater than 90 degrees, and an Acute has no angles over 90 degrees.
Thus, it is possible to have a (scalene or isoceles) AND (acute, obtuse, or right) triangle, but never an equilateral AND (obtuse or right). The angles can't be equal and 90+ degrees if all three must equal 180 degrees.
What is the edge length of a hexagon with a circle radius of 22 inches?
A regular hexagon is made up of six equilateral triangles. This means that the length of any one side of the hexagon is equal to the radius.
What is the side of an equilateral triangle if its area is root 243/4 sq cm.
Assuming you are specifying Area = sqrt(243/4) = 7.79422 Then the sides of the equilateral triangle are: 4.24264
Source: http://www.calculatorsoup.com/calculators/geometry-plane/triangles-equilateral.php
Best, Hunter
The height of equilateral triangle is 7root3cm find its perimeter
Let ABC be the equilateral triangle,
and PC be the line joining the mid point of A and C.
We know that equilateral triangle has equal angles which means
Now,
in triangle AHC
Sin(THETA) = AH/AC
That is...
Sin(60) = (7root3)/AC
or AC = (7root3)/Sin(60)
AC=14
Perimeter of equilateral triangle ABC = 3 x Side
= 3 x 14
= 42
1helpful
2answers
I have a lot tha is 152.95' X 119.88' X 130.00' X 50.00'. What part of an acre is this.
  1. This lot does not have the form or a regular quadrilateral (rectangle, square, parallelogram, etc.)
  2. So you cannot calculate its area, you have to know exactly the shape it has.
  3. With polygons, one usually cuts them into triangles.
  4. You have to cut it into two triangles,
  5. measure the base and the height of each triangle,
  6. use the area formula for the triangle ( area = heightX base/2)
  7. After you calculate the areas of both triangles, you add them to get the area of the the whole lot in ft^2.
  8. Using the conversion formula between acres and ft^2 which is 1 acre=43560 ft^2, you divide the area of the lot in square feet by the number 43560 ft^2 and express the result as a percentage or a fraction .
Hope it helps.
Thanks for using FixYa.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
