Really need more info but try this link or leave more info in the comment section.
iPod nano Support
Testimonial: "My son forgot his password after changing the password to many times and now the iPod won't connect to itunes or anything, any help is welcome!! Thanks."
SOURCE: 8GB iPod Touch Disabled
Hey,
read this page i posted
http://www.fixya.com/support/r977231-disabled_or_code_forgotten
Let me know if you need anything else.
Thanks,
Ekse
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Plug the
usb cable into the Ipod and NOT into the computer.
Hold the
Home Button down for 5 second (do not release it)
Then
Press and hold the Power Button for approx 10 secs (count them out)
Your iPod
will reboot.
Release
the power button and continue holding the Home button for an additional 27secs.
You may
see the screen go blank or not.
Plug the
USB end into the computer with itunes open.
Your ipod
will mount in recovery mode.
Restore
it and Your all set.
if you need any further help let me know.
Good Luck
SOURCE: Ipod touch 16gb, passcode forgotten screen reads disabled.
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
SOURCE: ipod disabled won't connect to itunes
But you will lose all your data
SOURCE: ipod touch is disabled itunes won't connect says
If you have forgotten your iPhone’s Passcode you will need to restore your phone via iTunes.
1. First you have to put your phone into the restore mode which is a slightly fiddly process.
2. Plug your iPhone into your PC or Mac with the USB cable
3. Press and hold the power button at the top and then slide to power off the iPhone
4. Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
5. After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
6. Open up iTunes and click on the Summary tab
7. Click on Restore to restore your iPhone. This will reset all your iPhone’s setting to the factory defaults, including the Passcode.
You should then follow these steps below to activate the passcode again.
