It connects to my pc but then it stops working, please kindly tell what is wrong with it? how can i make it work?
SOURCE: pen doesn't work
ok i had the same problem BUT i opened the mouse pen control panel and under info i unchecked the "support tablet PC feature" and to my amazement it worked. hope it works for you :)
SOURCE: Crazy Tablet - Genius 8x6
I have same tablet and the biggest problem is USB cable!!!
USB able is made from bad materials and the plastic/rubbery coating of inner wires of USB cable is very easy to brake, then the wires inside of the cable get connected between them selves and all the problem that you have starts.
I had those problems and all was solved by changeing the USB cable.
Changeing the USB is litle bit problematic becous it is connected to the tablet by microconnector that is wery hard to find (for me it was inpocibile). Becouse I couldn't find the matching microconnector I connected new cable to the one on the old cable welding the wires to the ones on the microconector . AND IT WORKED!!!
You may consider to by new tablet becouse this may seam complicated, but for me it was an interesting thing to do and it payed out. Just watch out to connect all the wires properly!!!!!
I hope this was helpful :)
Sorry for bad english ;)
P.S. If you have any problem while doing this write me here and all try my best to give you answers.
Steve from Serbia!!!!
SOURCE: Genius MousePen tablet 8x6 Isn't responding to the pen.
Have you tried replacing the Pen battery? Maybe it died.
SOURCE: Genius 8x6 tablet pen freezes
Try putting a new battery in it. Mine was having the same sort of problems, and they were pretty much entirely fixed by a new battery.
SOURCE: My Genius Mousepen 8x6 tablet isn't working with
My i608 pen stopped working today. I've had it for a month. The mouse was working fine, but the pen wouldn't work at all. Then I left the mouse on the pad and used the pen while the mouse was on the pad, and the pen started working again. Now it works even without the mouse on the pad. Did it re-establish the radio connection or something by doing that? Anyway, saved me the $25 replacement cost.
