1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
Hate to say this, but when power outages occur, things like vcr's are the first thing to fry. But if you feel that the vcr is fine as far as powering up, then unplug it from the wall socket for 30 minutes or so, plug back in and see results.
Try changing the channels on the VCR itself. If you can do that, then it would indicate a problem with the VCR's remote. If you are still unable to change channels on the VCR manually, it could indicate a circuitry problem, for which you will have to get the VCR serviced.
This is the problem with these combo units. When the VCR has
trouble (this sounds like a mechanical one) it inhibits the TV from
working as well cause they share the same power supply. It needs
a VCR expert to fix ya up.
I tell people all the time not to buy these combo units unless they
really need the conveinience cause you get to throw away the TV when
the VCR goes bad.
If you have tryed this with your VCR then Im guessing that there is a power supply issue. In most cases, a VCR would not be worth the repair or the diagnostic fee to inform you on how much the vcr will cost to repair. If you really want to playback VCR format buy a new one with a built in DVD recorder, buy some inexpensive DVD blanks, and put those Video tape onto the DVD format and they will never ever fade.
