My parking lights worked fine until I went to leave work at 11 oclock last night then I noticed my dash lights wouldn't work nor my tail lights
SOURCE: 2003 caravan dash lights
well...replace the stereo and the bulbs behind the dash. in order to do that you must pull the dash out to get behind the gauges be..carefull not to damage the ribbon of metal behind the gauges as to thats the power
SOURCE: 1995 Doge Dakota 3.9 v6 electrical issues
it sounds like you have a major electrical problem check all the fuses and look for any burned wires under the hood
SOURCE: DASH AND TAIL LIGHS DONT WORK
Check and see if you have trailer wiring on your truck. If so you do it may have a wire that is rubbed though the isulation and grounding on the body and shorting the circuit blowing the fuse. High resistance in a circuit is what blows fuses.
SOURCE: dodge ram 1500 the radio and dash lights are not working
did u look at the fuses under the hood there might be one there other than that sounds like you wiring went bad or the part of your switch is bad replace the switch
