I dropped my ASUS Q200E. The screen does not display images. When I hook to an external monitor the image is displayed on the monitor. I can even get a touch screen response showing on the monitor when I touch the notebook screen. How can I get my image back on the notebook screen display?
YOU DROPPED IT, THAT EITHER BROKE THE MONITOR OR THE CONECTION TO THE MONITOR BUT YOU SAY THAT WHEN YOU HOOK UP TO A MONITOR IT WORKS OK.YOU CAN FIX THE PROBLEM YOU GO TO E-BAY AND TYPE THE NAME AND MODLE NUMBER ONCE YOU ARE IN E-BAY LOOK FOR THE ASUS Q200E AND YOU ARE LOOKING TO BUY ONE FOR PARTS WITH A GOOD SCREEN...[REMINDER IT WOULD HELP IF YOU GET A PAY-PAL ACCOUNT.AND MAKE SURE YOU HAVE A MINI SET OF PHILIP SCREW DRIVER AND A MAGNET TO KEEP SCREW TOGETHER.
AND PAY CLOSE ATTENTION WHEN DOING THE REPAIR
PLUS YOU'LL HAVE EXTRA PARTS.
GOOD LUCK.
Posted on Feb 08, 2018
SOURCE: connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Posted on Mar 14, 2009
SOURCE: The screen on my son's Asus EEE PC is damaged
maybe..connect the external monitor and reboot to see if the system will find it and use it. Let us know what happens.
Dont forget to rate the advice.
http://www.aa1consulting.com
Posted on Aug 03, 2009
SOURCE: hello, i have one asus lcd monitor, the display is
Please look through the pictures, most monitors have the same problem; bad caps, very few has failed lamp assemblies due to poor soldering works.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 03, 2010
Testimonial: "yes it is helpful, i will send the photos to you by mail. thankyou"
SOURCE: My notebook Asus W7J BLANK when is turn on
Screen not working
are you able to hear the windows log in?
if you do but no image, most likelly your
video card is ruined. overheated or dropped maybe?
don't worry is bad but not that bad, there is a way to fix that by a professional.
take it to a computer repair shop and have them check the video card ask if they have a rework station or someone who may. they have to unsolder about 50 pins at the same time get a new card and solder it again.
sometimes they apply heat to it and it will work again but for just a few days maybe weeks but it goes bad again. so replacement is the best option.
I used to charge about 200 bucks but you may be able to ask for a rebate.
do not take it to a major computer store they would tell you there is no repair so you can go in and get a new computer
Posted on May 30, 2010
Testimonial: "exactly what i think"
Shine
a flashlight on the dark screen to see if you barely see the icons on the
desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If the video shows on the
external monitor that proves your video card is ok, ,but your lcd screen is
bad. The video will show on most systems when you reboot without you having to
do anything. Some systems will require you to hit the FN (Function key) + F1
thru F12. Hold down the FN key then hit the correct key for displaying on
the monitor (F1 thru F12). The correct key will normally have CRT/LCD on
it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
