20 Most Recent
ASUS Q200E 11.6" Touch- Laptop Computer Questions & Answers
Touchscreen does not display
YOU DROPPED IT, THAT EITHER BROKE THE MONITOR OR THE CONECTION TO THE MONITOR BUT YOU SAY THAT WHEN YOU HOOK UP TO A MONITOR IT WORKS OK.YOU CAN FIX THE PROBLEM YOU GO TO E-BAY AND TYPE THE NAME AND MODLE NUMBER ONCE YOU ARE IN E-BAY LOOK FOR THE ASUS Q200E AND YOU ARE LOOKING TO BUY ONE FOR PARTS WITH A GOOD SCREEN...[REMINDER IT WOULD HELP IF YOU GET A PAY-PAL ACCOUNT.AND MAKE SURE YOU HAVE A MINI SET OF PHILIP SCREW DRIVER AND A MAGNET TO KEEP SCREW TOGETHER.
AND PAY CLOSE ATTENTION WHEN DOING THE REPAIR
PLUS YOU'LL HAVE EXTRA PARTS.
GOOD LUCK.
Printer not recognized anymore
Is it a wireless printer?
- make sure you are connected to the correct network
Is it wired?
- make sure the cable is plugged in and functioning (check it with a different computer).
How to hook up my projector
For every projector ever made in the history of projectors?
All questions need full 'make model (what it is)'.
Google
make model manual
Kangro HP-45 tray not lifting to create space for papers
If the paper tray on your Kangaro HP-45 stapler isn't lifting to create space for papers, there are a few things you can try:
- Check the release latch: Make sure the release latch on the stapler is in the correct position. The release latch is typically located on the back of the stapler and should be in the "up" position to allow the paper tray to lift.
- Check for jams: Look for any paper jams or other obstructions that may be preventing the paper tray from lifting. Remove any paper or debris that you find.
- Check the lift mechanism: Check the lift mechanism on the stapler to make sure it's functioning correctly. The lift mechanism is typically located on the bottom of the stapler and should move freely.
- Lubricate the lift mechanism: If the lift mechanism is stiff or difficult to move, try lubricating it with a small amount of oil or silicone lubricant.
If none of these steps resolve the issue, it's possible that there may be a mechanical problem with the stapler. In that case, it may be best to contact Kangaro customer support or take the stapler to a professional for repair.
How to find MAD on an fx-9750GII calculator
You can use the built-in MAD function on the calculator by following these steps:
- Press the "STAT" key and then select "5:Distribution". Choose "1:Statistical Calculations" and then "4:Other".
- Select "4:MAD" and then enter your data set.
- Press "EXE" to calculate the MAD.
Caster holder broken and won't auto-stop after shred
I see you posted two questions on the same issue, and the other one was disjointed with no indication what the caster wheels were on.
Check the switch, they normally have On, Off and Auto.
Remove the head and clean all paper debris from underneath. You have a small piece of paper over the sensor and it is sensing that there is still paper for be shredded. Some have a small lever and if so, yours is stuck. Spray with WD40, and all the blades as well.
https://www.google.com/search?q=Ativa+MDM+8000
The caster wheels could all be removed and have it sitting on its base. The wheels are for use if you keep it in an office cupboard. You just replace the whole caster wheel or the whole set for $14..
https://www.google.com/search?q=Caster+wheel
Milnor commercial washer??
Yes, Milnor is a commercial washer manufacturer. They offer a range of equipment, including industrial and commercial washers. Their products are used in a variety of laundry applications and are designed to provide maximum efficiency, reliability, and performance.
Milnor commercial washer model # 30022T5X
The Milnor 30022T5X0 is a commercial washer that features a high-speed extraction system, low water usage, and a convenient front-load design. It offers a capacity of up to 25 pounds and can handle a variety of fabrics, including towels, sheets, and uniforms. The 30022T5X0 also features an energy-efficient design and an adjustable water temperature for better cleaning results.
Have a Staples Model SPL-727MM paper shreader that
I am sure you have already solved it or moved on but johnd393's comment at
https://www.fixya.com/support/t1766897-disassemble_mailmate_spl_727mm helped me.
To reach the screws in the tray drill 6 holes in the bottom plastic and use a really long screwdriver to access them.
I used a 12 inch uxcell #1 Phillips screwdriver, which also worked on the 2 long screw holes hidden under the feet. You could probably get away with 10 inch or a #2 Phillips but with #2 screwdrivers check the width of the shaft first as the screw holes under the feet were too small for the #2 I originally bought.
I have a problem with Riso SF5030, it shows error code P98-1061/ T98-1061. What maybe the problem
Hi!
Error codes P98-1061 and T98-1061 on the Riso SF5030 indicate an issue with the color drum's motor. This error code usually occurs when there is a problem with the motor or the wiring that connects the motor to the printer's control board.
Here are some steps you can take to troubleshoot the issue:
- Turn off the printer and unplug it from the power source.
- Check the wiring connections between the motor and the control board. Make sure that they are secure and not damaged.
- Check the motor for any physical damage or signs of wear and tear.
- If you have a replacement motor, try replacing the faulty one and see if the error code persists.
- If the issue persists, you may need to contact a service technician to diagnose and repair the problem.
It's essential to note that opening up the printer's internal components can be dangerous, and you should only attempt these steps if you feel comfortable doing so. If you are unsure or uncomfortable, it's best to contact a qualified service technician for assistance.
Regards
How to fix Riso cv 3230with error code p 01 -537
To fix the error code P 01 -537 on a Riso CV 3230, you will need to reset the machine. To reset the machine, press and hold the Stop/Reset button for at least five seconds. This will reset the machine and clear the error. If this does not work, then you may need to perform a deep reset of the machine. To perform a deep reset, unplug the machine from the power source and then plug it back in. Allow the machine to go through its startup sequence and then test the machine again.
How to clear error code 78?
Error code 78 is a common error code that can appear on a variety of devices, including computers, printers, and other electronic devices. The exact cause of this error code can vary depending on the device, but it usually indicates a problem with the device's hardware or software.
One of the first steps to clear error code 78 is to try restarting the device. This can often clear any temporary glitches or errors that may be causing the problem. If the error code persists after restarting the device, the next step is to check the device's manual or manufacturer's website for troubleshooting steps specific to that device.
If the device's manual or website does not provide any specific steps for clearing error code 78, the next step is to perform a general troubleshooting process. This may involve running a system scan for viruses or malware, checking for software updates or patches, or performing a hardware diagnostic test.
If these steps do not clear the error code, it may be necessary to contact the device's manufacturer or a professional technician for further assistance. In some cases, the device may need to be repaired or replaced to resolve the issue.
In summary, clearing error code 78 requires specific troubleshooting steps that may vary depending on the device. Restarting the device, checking the manual or manufacturer's website, performing general troubleshooting steps, and seeking professional assistance may all be necessary to resolve the issue.
