KIMIA# delete
startup-config Delete startup configuration (Reboot from defaults)
flash:// Delete a file from the flash (flash://filename)
WORD Specify name of file
KIMIA# delete startup-config
<cr>
Delete startup-config [y/n]? y
Startup file was deleted
KIMIA#
Processional only can to this activity..if you are able to do try it.. 1. Remove theSpindle.2. Remove the LeftHand Cover 3. Remove the RightHand Cover 4. Remove the Leftand Right Trims.5. Remove the FrontPanel 6. Remove the TopCover and Window7. Remove all theMedia Deflectors 8. Remove the BackPlaten 9. Remove the MediaSensor10. Remove theSpittoon 11. Remove theCutter Assembly 12. Remove theCutter Guide Bracket 13. Remove the DriveRoller EncoderSensor
You can go to this site and pick which printer and get your driver (http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1153501&taskId=135) Hope this works
error 1290, simples de resolver, basta ligar a maquina com a tampa aberta, voltara a funcionar, depois tem q entra no menu t?cnico , e procura counter, e reseta all, esse procedimento zera o contador, mais explica??es msn: [email protected]
