The motherboard is : SONY VGC-RA304 MAINBOARD MOTHERBOARD P / N 178 901 721 PTGD -VX My sony- vaio desktop vgc - RA304 , has a new WD 500 GB hard disk with no OS, the old hard drive is out of order ! My problem is that I can no longer start with the bios and see it, because I think it is corrupt and can not see the video card. "No Signal" is shown, even with VGA and HDMI. The graphics card is : GIGABYTE (GeForce 210 DDR3 TC ) - 512I GV- N210TC I tried with another PCI video card , but nothing. On the computer there is no onboard VGA . I already tried to reset the bios , from the battery and the jumper ! But nothing . Do you have any suggestions that you would recommend ?
It's an old model, 1 - CDrom and HDD lights blink? if not please try turn on without the cmos battery. IT's an 11 year old pc the battery is almostly dead. 2 - CPU fan turn on loud and doesn't low rpm? Fan dirt or bad motherboard.
Testimonial: "I really cleaned everything and before changing the hard drive everything worked. The battery had been changed, but I feel the same as without. Everything seems to work correctly, all fans are working, the hard drive start, but I can not see anything. I changed two grafic card and two monitors. What can it be?"
SOURCE: Motherboard upgrade - Sony Vaio VGC-RB62G - RAID 0 issue
Why don't you try to get your main drive running before getting into Raid Configurations. Set your single drive to Master and run setup telling it you have one drive. Once you are satisfied that it is not some other fluky error, put in the other drive and I believe if SATA you don't even have to worry about Master Slave. Go about your boot and go into setup again. Hopefully all is good with the world and all that has to be done is fix up BIOS. No matter what, there is never an " out of the box " clean system. Make sure you plug your cables in correctly. I assume you're running EIDE. You'll get it.
SOURCE: Greetings, i have a sony vaio vgc-ra820g desktop
it supports all intell processors except i7 and all amd
please vote for it and thanks for using fixya
