GE Monogram freezer door opens when closing refr door. When closing the refrigerator door the freezer door opens enough to break the door seal and temps go up in the freezer.
I will try your recommendation. Thank you very much. What did we do before the internet. This is great.I will try your recommendation. Thank you very much. What did we do before the internet. This is great.
AnonymousMar 12, 2014
Monogram 42 inch freezer door is warpedMonogram 42 inch freezer door is warped
You can't post conmments that contain an email address.
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
its the damper vent door thats located in the upper left area of the refrigerator compartment and this door breaks and then cant shut to close off the cold air from the freezer entering the refrige,general electric has had a bad problem with these damper vent doors,now they have a new and improved or so they say damper vent door,its about $100.00+
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp. The problem could be the electronic control if you have one or the mechanical linkages.
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
with the domestic door open hit the door switch and you shoud hear or feel the movement of air. i say you have no air circulation or a blocked condenser drain water is not getting back to the evaporator tray
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
