Acer T-180 hangs at "Verifying DMI Data"
The cause of this problems is a corrupt boot files, Settings for hard disk drive are not correct,Floppy diskette or CD in computer causing issue, Boot devices not set properly, BIOS corrupt or misc. hard disk jumper setting not set properly, Connections loose or disconnected, Bad Hard disk drive or other bad hardware.
Note: Try this first. Check the cable setting of your hard disk in the BIOS. try swithching it to IDE, SATA, RAID. save your seetings and restart your computer.
if problem still exist... Follow this steps..
Step 1: If you have a USB stick with capacity of 4Gb and up or another hard disk... try installing a fresh Operating System in the USB stick or in the extra hard disk that you have.. after you install.. boot to bios and set the Primary boot in the extra hard disk or Removable Device (USB) save your settings and restart.. your computer will start normally booting the windows in your newly installed extra hard disk or USB stick. when you are in the Desktop, now try accessing your old hard disk and copy your files.. after you backup your files to the new installed hard disk. go to step 2.
Step 2: Turn off your computer... uninstalled the newly installed hard disk or USB.. after you uninstalled the hardware.. turn on your computer and reinstall your Operating System again. if the problem still exist go to step 3.
Step 3: if the problem stil exist. i think ther is something wrong with your hard disk.. try installing the OS again in second partitioned of your hard disk.. create first partition, then second partition. then installed your OS in second partition... if the problem still exist and you cannot go to windows desktop.. maybe your hard disk drive is damaged...
Hope I Can Help
CLCTECH
