Hello I have a TOSHIBA LED 46L5200U TV where picture stoped working and the volume is working.When I turn the TV on, the Toshiba logo comes on for a second and then the screen turns black if i get close to the tv (almost nose to screen) and get to the right angle or shine light at the right spot i can FAINTLY see the menu and scroll through its options.What will be the problem.Please help.
Check and replace its back-light inverter board. Contact any service technician. Gopakumar Gopalan Google
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
SOURCE: TV will not turn on/black screen/picture/green LED is red/blinkin
I had the same problem for my TV which was model number: 42PF9631D/37 and I went to get the software update at http://www.p4c.philips.com. Type in your model number, then click on the right model. Then click on software & drivers in the left column. Then download the correct software update to a flash drive. The flash drive must be completely empty except for this file. Then unplug your TV, and plug the flash drive into the USB port. Plug your tv back in, and the software update will upload. It fixed my TV instantly.
SOURCE: hdtv-dlp has no sound or picture
this sounds like a dmd board problem. these are digital modules attached to the light engines usually. samsung, rca, hitachi, have shown similiar symptoms. some units have capacitors on the boards that can be replaced, but these are dual-layer pcb's that are tough to unsolder without proper soldering iron temperature and good small gauge solder-wick. or solder pump tool. the electolytic caps. are usually 1000uf / 10v, 330uf / 10v, or 470uf / 10v. alot of the time the capacitors will "vent" or swell-up on top which helps spot faulty component. we always increase voltage rating to 16v-25v for more reliable operation. always use 105 degrees high- temperature replacement caps.
SOURCE: Toshiba big screen popped
oh boy, that sucks, time to head to the local electronic repairs store. or if you still have the warranty then take it back and make a stand!
SOURCE: Toshiba 40" turns on for a few seconds, then turns off. No picture!
Consider having it repaired as it should be in warranty.
