1992 Jeep Wrangler Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Transfer case locks into low gear but front wheels do not pull
Wheb I go into four wheel drive my transfer case locks into low range the front drive shaft locks in but it does not seem like the front wheels are pulling.
Do the front hubs have to be locked in or is there a problem elsewhere?
  • Anonymous Mar 13, 2014
    won't goin gear low or high range
Brandon Kurkierewicz
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 23, 2013
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
502
Points
Those dodges don't have hubs, your front left tires able is always spinning, the transfer case switch the into 4 wheel and spins the front drive shift, the there's a actuator on your axle that moves a coupler over to axle splines and your inn4 wheel drive
Tom Cook
Level 2:
  • Expert 55 Answers
  • Posted on Jun 11, 2009
Tom Cook
Expert
Level 2:
Answers
55
Questions
0
Helped
16607
Points
152
You have to have your front hubs locked in for four-wheel drive to work
2answers
What causes 4x4 switch to just blink when trying to put in 4 wheel drive 2000 gmc Jimmy
The reason the light is flashing constantly is because the vehicle is sensing that four wheel drive(4WD) is not working. These 4WD systems use vacuum from the engine to engage/disengage to front axle. The vehicle probably has no vacuum going to the front axle, which would not allow the 4WD shift to complete, which would then leave the light on the dash flashing.
First thing to check is that the vacuum actuator on the firewall is working as it should.
2helpful
2answers
My new 2007 H3 drives in 4x4 all the time I placed the transfer case in N (neutral) and the vehicle will not engage to drive or reverse. Does placing it in neutral put the entire drive in neutral.
Does placing it in neutral put the entire drive in neutral???? Yes . Taking the vehicle to a qualified repair shop that has a factory or professional scan tool to read code's in the transfer case control module is what you should do , you probably have no clue of the complexity of these 4X4 systems . How many buttons on the switch on the instrument panel ?
The BW 4493/4494 transfer case features a 4-button shift control switch (1) located on the instrument panel. When the vehicle has the ignition key in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position begins flashing to inform the driver that the transfer case shift control module has received the request for a new mode/gear position. The lamp continues to flash until all shifting criteria have been met and the new mode/gear position has been reached, or has been engaged. Once the new mode/gear position is fully active, the switch indicator lamp for the new position remains ON constantly.
During normal driving situations, the transfer case operates in the 4HI mode. When the 4HI mode is selected, the transfer case shift control module sends 12-volts to an electrical motor, which is the transfer case encoder motor. This motor rotates the transfer case shift detent lever shaft which moves the shift forks and range sleeve to obtain different modes/ranges.
The BW 4493/4494 transfer case has the added feature of also providing the driver with 3 manual mode/range positions:
ā€¢ 4HI - 4-Wheel Drive High Open
ā€¢ 4HI Lock - 4-Wheel Drive High Locked
ā€¢ 4LO Lock - 4-Wheel Drive Low Locked
The driver may choose to select any of these mode/range positions while driving the vehicle. However, the transfer case will not allow a shift into or out of 4LO Lock unless the following criteria has been met:
DTC B0790 Transfer Case Neutral Indicator Circuit Malfunction
DTC B2725 ATC Mode Switch Circuit Malfunction
The mode switch circuit consists of 5 modes. The transfer case shift control module supplies a regulated 5 volts, DC to the switch through the 5-volt regulator circuit. The current travels through the resistor of the currently pressed mode button. The current is then returned to the transfer case shift control module through the switch signal circuit.
The transfer case shift control module constantly monitors this signal voltage to determine the condition of the mode switch circuit.
When each of the modes are selected they will complete a circuit through their own specific resistor while the button is pressed. The transfer case shift control module continuously monitors the switch input to determine whether the Neutral, Differential Lock, 4HI, 4HI Lock, or 4LO Lock mode was selected by the driver.
DTC C0306 Motor A or B Circuit Malfunction
The transfer case motor is a bi-directional, permanent magnet, D.C. motor. When energized, through motor control A or motor control B, the ground is provided by the opposing motor control circuit and then grounded through the transfer case shift control module ground circuit, the motor, through a series of gears, rotates a shaft which moves the mode and range forks to shift the transfer case between the following ranges:
ā€¢ 4HI
ā€¢ 4HI Lock
ā€¢ 4LO Lock
ā€¢ Neutral
This DTC detects an open, short to voltage, or short to ground in the motor control A or motor control B circuits, or an open, or short to ground inside the motor.
DTC C0327 Encoder Circuit Malfunction
DTC C0329
DTC C0359
DTC C0550
The Borg Warner (BW) model 4493/4494 NR4 transfer case is a 2-speed, full-time 4WD, transfer case. The transfer case has an external planetary type differential, which has 2 different sets of pinion gears. The planetary differential provides a 40/60 torque split front/rear full-time. This means the front and rear propeller shafts are constantly being driven for maximum traction in all conditions. A high/low planetary carrier assembly provides the high and low ranges, which is a 6-pinion gear, sun gear, and annulus gear arrangement, giving a 2.64 low range reduction ratio in the BW 4493 and a 4:1 ratio in the BW 4494.
My 98 blazer 4x4 wont work?
Which of these does your vehicle have ?
Transfer Case - NVG 233-NP1 (Two Speed Selectable)
Transfer Case - NVG 136-NP4(One Speed Automatic)
The New Venture Gear NV233 is an electronic shift transfer, with the following three modes of operation, Two-wheel drive high range, Four-wheel drive high range, Four-wheel drive low range. The gear reduction for low range is provided by a planetary gear set. The floor-mounted shifter has been eliminated. A switch, located on the upper right side of the instrument panel, is used to select the operating range. The indicator lamps on the switch show the current mode of operation. When the four-wheel drive has been selected, the four-wheel drive indicator lamp on the switch is designed to turn on when the front axle has engaged.
Automatic Transfer Case
The single speed automatic transfer case system shifts automatically from rear wheel drive to four wheel drive when the transfer case shift control module (TCSCM) senses the difference in rotation speed of the front propeller shaft and the rear propeller shaft . Two vehicle speed sensors, one located at the rear output shaft area of the transfer case, and the other, located at the front output shaft area of the transfer case, send front and rear propeller shaft rotation speed information to the TCSCM.
When the front and rear output shaft rotations remain the same, the TCSCM sends pulse width modulation signals to the encoder/motor to keep the transfer case in rear wheel drive. When the front and rear output shafts rotations are different, the shift control module sends pulse width modulation signals to the encoder/motor to engage the transfer case into four wheel drive.
The system will automatically transfer a percentage of torque to either the front or rear axles as required to stop all wheel slip. When the front and rear output shafts rotations return to the same speed rotation, the shift control module sends pulse width modulation signals to the encoder/motor to position the transfer case back into rear wheel drive.
When the transfer case is engaged into four wheel drive, a lamp indicator on the instrument cluster will light. The automatic transfer case system is completely automated, no transfer case control button switching system is required.
Do you know what diagnostic trouble code's are ?
DTC C0300 Rear Speed Sensor Malfunction
DTC C0305 Front Speed Sensor Malfunction
DTC C0308 Motor A/B Circuit Low
DTC C0309 Motor A/B Circuit High
DTC C0310 Motor A/B Circuit Open
DTC C0315 Motor Ground Circuit Open
DTC C0374 General System Malfunction
DTC C0376 Front/Rear Shaft Speed Mismatch
DTC C0550 ECU Malfunction
DTC C0611 VIN Information Error
DTC C0895 Device Voltage Malfunction
Not OBD2 engine code's .
2answers
4 wheel drive won't engage
Which do you have ?
Transfer Case - NVG 236 (Two Speed Automatic)
The NV236 transfer case is an automatic transfer case with three drive ranges. Shifting from rear wheel drive to four wheel drive is done automatically when the transfer case shift control module receives wheel rotating slip information from the speed sensors. The transfer case shift control module then engages the transfer case motor/encoder to position the transfer case from rear to four wheel drive. When the transfer case shift control module receives information that the wheel rotation is the same on both axles, the transfer case shift control module sends position information to the motor/encoder to put the transfer case back into rear wheel drive. The three drive ranges are 2HI, 4HI, and 4LO. The 2HI position is for normal driving with the rear wheels pushing the vehicle. The 4HI, position is for driving through sand, snow, mud, gravel, or heavy rain at normal or slightly below normal speeds. The 4HI engages the front axle to allow for four wheel drive. The front axle is pulling the vehicle, and the rear axle is pushing the vehicle. The 4LO range is used for off road driving, heavy snow, deep mud, or shallow fording. The 4LO is similar to the 4HI except that the gearing in the transfer case is set for low speed and high torque. The NV236 is manufactured at Syracuse New York by New Venture Gear a division of New Process Gear for General Motors.
Is the switch light on or flashing ? If you have automatic 4x4 there are several DTC'S that can set >
DTC B2725 ATC Mode Switch Circuit Malfunction DTC C0300 Rear Speed Sensor Malfunction DTC C0305 Front Speed Sensor Malfunction DTC C0308 Motor A/B Circuit Low DTC C0309 Motor A/B Circuit High DTC C0310 Motor A/B Circuit Open DTC C0315 Motor Ground Circuit Open DTC C0323 T-Case Lock Circuit Low DTC C0324 T-Case Lock Circuit High DTC C0327 Encoder Circuit Malfunction DTC C0362 4LO Discrete Output Circuit High DTC C0367 Front Axle Control Circuit High DTC C0374 General System Malfunction DTC C0376 Front/Rear Shaft Speed Mismatch DTC C0387 Unable to Perform Shift DTC C0550 ECU Malfunction DTC C0611 VIN Information Error
Error message repair 4wd
I guess you probably don't know what transfer case you have ?
SERVICE 4WD
Refer to
?ā‚¬Ā¢
Transfer Case Description and Operation in Transfer Case - NVG 149-NP3
?ā‚¬Ā¢
Transfer Case Description and Operation in Transfer Case - NVG 246-NP8
?ā‚¬Ā¢
Transfer Case Description and Operation in Transfer Case - NVG 261-NP2
?ā‚¬Ā¢
Transfer Case Description and Operation in Transfer Case - NVG 263-NP1
The NVG 246 EAU provides 5 modes, Auto 4WD, 4HI, 4LO, 2HI and Neutral.
The four manual mode, or range gear positions, of the NVG 261 transfer case are:
?ā‚¬Ā¢
2HI - 2 wheel drive high range
?ā‚¬Ā¢
4HI - 4 wheel drive high range, part-time
?ā‚¬Ā¢
4LO - 4 wheel drive low range, 2.72:1 gear ratio reduction
?ā‚¬Ā¢
N - Neutral, 4 wheel
The NVG 263 transfer case provides the driver with 4 manual mode/gear positions:
?ā‚¬Ā¢
2HI - 2 Wheel Drive high range
?ā‚¬Ā¢
4HI - 4 Wheel Drive high range
?ā‚¬Ā¢
4LO - 4 Wheel Drive low range
?ā‚¬Ā¢
Neutral
With the info I've given you ,you should be able too now !
There is probably a code stored somewhere !
DTC B0790 DTC B2725 DTC C0300 DTC C0305 DTC C0306 DTC C0321 DTC C0327 DTC C0359 DTC C0374 DTC C0379 DTC C0550.
95 nissan 4x4 truck. four wheel drive light comes but does'nt en
the front axles have pinon gear box that the shaft from the transfer case goes to, it has a vacuum hose to it or a solenoid actuator check these for proper function this is how the power is turned on to the wheels.
2helpful
2answers
HOW TO USE 4 WHEEL 1980 CHEVY K20 PICKUP
have truck running,,put shifter in neutral,,shift into high lock 4x4,then put truck into gear,,u can shift from high lock to high gear,,from two wheel to four wheel,,in high only,,if u want to shift transfer case in low,,u have to put truck in ,,neutral,,first,,
2answers
4x4 wont engage
the motor on the back of the transfer case may be stuck knock on the motor lightly with a hammer when switching the the switch May need a motor
1helpful
1990 Suzuki Escudo 4 wheel drive
As far as I know the procedure should go something like this...
Stop the vehicle, engage the parking brake and if applicable, get out and turn the hubs on the front wheels from Free, to Lock.(You may not have these on a Suzuki, they may be auto-lockers)
Get back in the vehicle and put the transmission shift selector into Neutral.
If you have a manual transfer case, move the selector-shaft to 4x4-High, or 4x4-Low -- whichever is desired. Now, putting the vehicle in gear with the transfer case is sometimes somewhat difficult. As long as the vehicle's transmission is in neutral, don't worry, the gears inside the transfer case are big and beefy -- Don't be afraid to be rough -- Again as long as the transmission is in neutral. You may also have to disengage the parking brake and slightly let the vehicle roll forward or back with your foot-brake to get the Transfer case to lock into place.
Once 4x4 of the selected High, Or Low range is selected, usually indicated by the vehicle jerking slightly with a slightly loud clank/thud. Move the Transmission selector out of neutral into your desired gear (Drive if Automatic, if Manual, whichever gear you pull out from). and voila! You should now be in 4-Wheel-Drive.
To disengage 4-Wheel-Drive. Just reverse the steps.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
