768 is a bad printhead. It could mean that your ph ribbon is disconnected from the ph, or you actually have too many bad dots to print.
Even if you could temporarily get a workaround for this issue, you will need to replace the printhead if your ribbon isn't disconnected. Contact the company to get a ph sent to you. 1-800-543-6650
The problem is your printhead is bad . do a print test by presing both arrow buttons at tah esame time for two seconds, look fo rthe line that reads bad dots. if the value i sgreater than 000 yu have a bad printhead
jay
Check to make sure the ribbon cable that connects to the printhead is actually connected. A 768 error means that the printhead isn't connected, or it's completely blown. The ribbon may just need to be seated correctly, or the printhead needs to be replaced.
