Unable to open. Theme corrupted
SOURCE: when i apply themes in my nokia 3110c it shows
Those themes will be either from an unauthorised source or having an expired certificate.Please do not install such themes on your device as it will contain viruses which may be harmful to your phone.So remove it from your phone as soon as possible.The themes which are not supported by your phone will also show a corrupted message.
SOURCE: theme corrupted
hai my mobile is nokia 3500c . ihave a small problem i have unable to open theams are shown corrupted
SOURCE: nokia default theme corrupted.whenever i apply
Format your phone using this code okay. *#7370# or *#7780#. Dial this code. This will reset your phone to factory settings. After the phone resets, it restores any corrupted files in your phone.
Take note: Be sure to back-up first your contacts and etc.
SOURCE: i m unable to open any theme in my mobile.
http://discussions.europe.nokia.com/t5/Phone-Applications/Themes-dont-get-loaded-in-Nokia-3500-classic/m-p/249531
try out this..
SOURCE: my mobile nokia 3110c not working theme.every i`m
Your phone momroy is full ! U have not set the theme in mobile ! You have remove or delete the same items ! Then u have set the theme in mobile !
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
