SOURCE: Purchased new Iomega 1 TB Home Media network HD,
you have to initilize the disk in disk management utility, heres how (windows XP)
Note: If you're viewing the Classic View of Control Panel, you won't see this link. Just double-click on the Administrative Tools icon and skip to Step 4.
In a few seconds, Disk Management will load on the right side of the Computer Management window.
Note: If you don't see Disk Management listed, you may need to click on the + icon to the left of Storage to expand the option.
SOURCE: I don't know how to make a wireless connection
Make sure you are at least using a CAT 5 cable with your device. You will want to do a couple things as well. Give your device a static IP address (manually configure the IP) from withing the devices interface (login to your device, System tab on the left and Network tab on the right). Next go to your folders you are wanting to share and click the DLNA button that corresponds with the folder you are wanting your media server to share out. You should be good to go.
SOURCE: my iomega network drive just decided to not show
Reboot the network drive and the router, this usually works when mine doesn't show. You may need to disconnect any mapped drives, as it may show with a new ip address. Computer may also need to be rebooted.
