Not reading the disc.
There are two common poblems that occur with the 300 DVD player. Either the machine will not power up at all and the power indicator won't work or after a disk has been inserted the on screen display will say "loading disk" but then say "bad disk".
First remove the top cover secured wih screws, you will now be able to identify the power supply board. At the output connector measure the 5 volt output with a voltmeter. If less than 4V, than the unit will not work properly. The filter capacitors are bad. Replace C10, 2200uf@ 10V and C11, 1000uf@10V. Because of the limited space provided, use capacitors of the same physical size. Do not try to pigtail a larger cap in its place. The circuit will not operate properly. I can supply these if you can't find them locally.
