La laptop leia sd cards sin problema pero de pronto no reconoce ninguna
Thank You,
Dell-Jesse L
Dell Social Media and Communities
SOURCE: Necesito realizar el test de una Laptop Inspiron 8600
My spanish is very poco, but I think you want to start a diagnostics test, and need the combination of keys to start?? That would be the Fn + the Power key. Turn the computer off. Press and HOLD the Fn key, then press and RELEASE the power key. Keep the Fn key down until the screen says that you are starting in the "diagnostics" mode. You will then see prompts to ask if you want to conduct a full diagnostics test or a custom one. If you just want to check one or more parts of the system, choose the custom and select what you want to test. Otherwise a full test will cover all system hardware and will take about an hour.
SOURCE: hola yo tengo una DELL
Remove the CMOS battery and re insert again..you can find CMOS battery located on the motherboard...
SOURCE: debo resetear la bios de mi dell inspiron 1525 y no se como
There are 2 ways you can reset your bios.
1.
On the motherboard there is
a small watch battery. Remove this battery along with the power cable
from the power supply. Hold down the power button to fully discharge the
system. Wait 2-3 minutes then reinstall the battery and plug in
your system. Your reset is now complete
2. Some motherboards have a 3
pin jumper by the battery. Lets say that the jumper is on pins 2 and 3.
Remove the jumper while the machine is OFF and place onto pins 1 and 2.
Power on your machine for a minute. (Note: Your system will not POST).
Shutdown your machine and put the jumper back to pins 2 and 3. Your
This is a great troubleshooting
step for those of you having POST issues or no POSTing at all. Like
other troubleshooting steps, this will not always work but usually will
depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
En primer lugar tener una tarjeta de memoria si tiene una en su tel?fono y luego apagar el tel?fono. Reinicie el tel?fono sin la tarjeta de memoria en el tel?fono e intente de nuevo la c?mara. Si esto no funciona entonces le sugiero que visite nuestra p?gina de Motorola Software Update para ver si hay actualizaciones para el tel?fono. Copia de seguridad de su informaci?n al ordenador mediante Microsoft ActiveSync o Windows Mobile Device Center para asegurarse de que no se pierde ninguna informaci?n durante la actualizaci?n. Maestro lo Perd? mi realmente el ?ltimo recurso si no otra cosa se puede resolver, pero en este caso, tambi?n aseg?rate de que tienes todo lo que una copia de seguridad como toda la informaci?n se perder? desde el tel?fono.
