20 Most Recent M-Audio PROJECT MIX I/O Sound Card Questions & Answers
2answers
Desconecte mi project mix de
ytengo el mismo problema formeate la pc y de hay para no logro aserla funcionar intaldo los driver,,,tarjeta firewire cables....y no la recnoce mi pc.....ya ni se que hacerrrr
5/23/2015 5:39:04 PM • M-Audio PROJECT... • Answered on May 23, 2015
I started to have this
Hi maricrisdfor ,
you could go here to download the W 7 compatible driver :
http://www.m-audio.com/index.php?do=support&tab=driver&PID=327212ef66595c9bc875d0dd268b96cb&serie_ID=2#tabs
Best regards ,
fanaudi .
8/31/2011 4:10:36 PM • M-Audio PROJECT... • Answered on Aug 31, 2011
0answers
3answers
My PC or Mac won't
Can you try hooking it up to a different Mac?
We need to figure out if the problem is with the Mac or the unit itself ;)
11/15/2010 1:06:51 AM • M-Audio PROJECT... • Answered on Nov 15, 2010
Computer not detecting m-audio
is this your first time of connecting the m-audio to your computer? Or was it working before and stopped. Also, what operating system are you running on your computer?
Please answer the above questions so that I can proffer an accurate solution to your problem.
I look forward to your reply.
Bye for now.
8/2/2010 9:49:29 AM • M-Audio PROJECT... • Answered on Aug 02, 2010
Can't get Yamaha motif to work with new M-AUDIO
Go to your computers control panel find your devices section locate your settings for your synth in/out to see if there active or not. consider to go tothe M-Audio website to chec for recent downloads for ti. You may need to upgrade your windows?
6/29/2010 9:05:31 PM • M-Audio PROJECT... • Answered on Jun 29, 2010
All line/mic inputs work except for condensers,
Most probable cause is an overheated or burnt out capacitors on the system board. As long as software and drivers are up to date. You can test any electrical componenet with an ohmmeter. Test resistos or capacitors from the bottom of the control board. If you have a very ow or no reading, that is the bad capacitor. They have numbers on them for replacement. You can get one at shopjimmy.com
10/21/2009 5:30:04 PM • M-Audio PROJECT... • Answered on Oct 21, 2009
2answers
My M-audio FireWire 410 doesn't work
It sounds like you may be experiencing a configuration issue with your M-Audio FireWire 410 audio interface. Here are a few steps you can try to troubleshoot the issue:
  1. Check the connections: Make sure that the FireWire 410 is securely connected to your computer and that all cables are properly plugged in. If the connections are loose or faulty, it can cause problems with the audio output.
  2. Restart the device: Sometimes, restarting the audio interface can resolve issues with the audio output. To do this, disconnect the FireWire 410 from your computer, wait a few seconds, and then reconnect it.
  3. Update the drivers: It is possible that the drivers for your FireWire 410 may be out of date or incompatible with your operating system. To update the drivers, visit the M-Audio website and download the latest drivers for your device. Once the drivers are installed, restart your computer and try using the FireWire 410 again.
  4. Check the settings: Make sure that the FireWire 410 is selected as the default audio device in your operating system's audio settings. You can access these settings by going to Control Panel > Hardware and Sound > Sound. Under the Playback and Recording tabs, select the FireWire 410 and click the Set Default button.
If these steps do not resolve the issue, it is best to contact M-Audio support for further assistance. They should be able to provide you with specific guidance for troubleshooting the problem with your FireWire 410.
2/24/2023 2:16:59 PM • M-Audio... • Answered on Feb 24, 2023
M-Audio Prokeys 88 Premium Piano. No sound in headphones and in audio out. Help Me Please!
Hi, please restart your piano and attempt to get sound again. If not working still, then you can attempt a factory reset. Otherwise, please change the head phones or audio out device and play some test songs or keys. Thank you.
11/10/2022 12:40:01 AM • M-Audio... • Answered on Nov 10, 2022
3answers
I want a YouTube to Ringtone Converter, anyone
Here it is http://video2ringtone.com/
7/5/2022 3:31:35 AM • M-Audio... • Answered on Jul 05, 2022
I need a pin out diagram for audiophile 192. I wand to do myself the break out cable
Measure it myself from original card and cable. M-Audio Audiophile 192 Pinout DB25 Male, front view: 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 Female Midi, front view: 1 4 2 5 3 In and Monitor cables are connected to same pins (so are interchangable): 22 In L Gnd - Monitor L Gnd: iLg 21 In L Tip - Monitor L Tip: iL+ 09 In L Med - Monitor L Med: iL- 08 In R Gnd - Monitor R Gnd: iRg 07 In R Tip - Monitor R Tip: iR+ 20 In R Med - Monitor R Med: iR- Main OUT: 19 Out L Gnd: oLg 18 Out L Tip: oL+ 06 Out L Med: oL- 05 Out R Gnd: oRg 04 Out R Tip: oR+ 17 Out R Med: oR- Midi (Female connectors): 11 Midi Out 4 mO+ 12 Midi Out 2 mOg 24 Midi Out 5 mO- 13 Midi In 4 mI+ 25 Midi In 5 mI- Midi In specifications leave Gnd pin 2 unconnected. So connector its: 01 02 03 oR+ oRg oL- iR+ iRg iL- 10 mO+ mOg mI+ 14 15 16 oR- oL+ oLg iR- iL+ iLg 23 mO- mI-
5/6/2019 3:34:47 PM • M-Audio... • Answered on May 06, 2019
M-Audio PROJECT MIX I/O Sound Card Logo
19 questions posted
Top M-Audio Computers & Internet Experts
Marvin
Marvin
August Brown
August Brown
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Computers & Internet
Most Popular Question
started
  • Computers & Internet
