Hyundai Master
- Posted on Jun 04, 2009
Re: changing front and rare break pads in hyundia excel
This front::
- Raise and support vehicle, then remove wheel/tire assembly.
- Remove lower bolt and caliper assembly. Position assembly aside using suitable wire.
- Remove brake pads and shim.
- Bottom piston in caliper using suitable tool.
- Install new brake pads and attach shim to the outer pad. Tighten lower bolt to specifications.
this for rear::
1. Raise and support vehicle, then remove wheel/tire assembly.
- Remove axle nut, then the hub and drum assembly.
- Remove end shoe springs, cylinder and hold-down spring.
- Remove shoes and adjuster as an assembly.
- Reverse removal procedure to install, noting the following:
- Apply suitable grease to backing plate shoe contact surfaces.
- Install shoe hold-down pin, then assemble return spring with the pushrod shortened.
- Pull parking brake lever fully upward. Repeat process several times.
